[Qgis-psc] [QGIS-Developer] Fwd: QGIS 4.0 publicly announced - right time for propose and implement breaking changes?
Dalheimer, Jan
jan.dalheimer at sweco.se
Fri Apr 25 11:45:12 PDT 2025
I think part of the confusion (at least for me) might be because there is no clear information (that I can find) on what breaking changes are allowed in QGIS 4 (and between major and minor versions more generally).
Even such a relatively simple question such as “if any breaking changes apart from those necessary to switch to Qt 6 are allowed for QGIS 4” isn't quite clear to me, even with Jürgens response below.
The closest to written documentation on this I can find is the one sentence here: docs.qgis.org/3.40/en/docs/developers_guide/codingstandards.html#api-compatibility
For core developers and other “longtimers” this is might be second nature, but for us not in that group it’s not. This might also be why there is not written documentation yet; those who know don’t need the documentation, and those who don’t can’t write it.
So, to help me, Vedran and others, could someone with the right knowledge document the policy on breaking changes (as a QEP, in the documentation, or elsewhere)? Something that addresses questions such as:
* When may C++ API be broken? When may C++ ABI be broken?
* When may Python API be broken?
* Does QGIS only care about backwards-compatibility, or also forwards?
* Are object names (such as of widgets) considered API subject to the previous questions, or implementation details? (some plugins depend on the names)
* Is deprecated functionality exempt from the above? (that is, if the answer to the first question is "only in major versions", may methods marked as deprecated be removed within a major version after having been deprecated for a given number of versions or time)
* When may significant UI changes happen?
* What about file formats (such as project files)?
* What is the process for breaking changes? Do they always require a QEP?
I think it would also be helpful to get some indication of the longer-term strategy (even if it's just a general thought for now, not a hard deadline). If QGIS 4 is intended to just focus on Qt 6, does this mean that there'll be a QGIS 5 in the near future (say 2-4 years) which may include other breaking changes? Or will the next opportunity for breaking changes be in another 7 years?
Jan Dalheimer
Sweco Sverige AB | Gävle
-----Ursprungligt meddelande-----
Från: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> För Jürgen E. Fischer via QGIS-Developer
Skickat: den 25 april 2025 12:43
Till: qgis-psc at lists.osgeo.org
Kopia: qgis-developer at lists.osgeo.org
Ämne: Re: [QGIS-Developer] [Qgis-psc] Fwd: QGIS 4.0 publicly announced - right time for propose and implement breaking changes?
On Fri, 25. Apr 2025 at 10:14:19 +0200, DelazJ via QGIS-PSC wrote:
> Just for reference, there are:
> https://urldefense.com/v3/__https://github.com/qgis/qgis4.0_api/issues
> __;!!HBVxBjZwpQ!0lUzry6JbWxdJvhAAj8ho2IsXcYFRsZirGjag3IXisILGrwh2umAtT
> pqs5zSXPTTD5BWTUUY5EmYytKBtVJ-03w1XqMVsvDQ7w$ (mainly developer
> oriented, but I think there are issues that may interest end users)
Although this is a bit misleading now - originally we wanted to release 4.0 when we introduce above API changes.
Now we need to switch to Qt6 - because 5 goes EOL - but that's a API break in itself, although we don't do above API changes or other breaking changes in QGIS itself. And not even huge enhancements - just the few things like CMYK that are already there, but only work with Qt6.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://urldefense.com/v3/__https://www.norbit.de__;!!HBVxBjZwpQ!0lUzry6JbWxdJvhAAj8ho2IsXcYFRsZirGjag3IXisILGrwh2umAtTpqs5zSXPTTD5BWTUUY5EmYytKBtVJ-03w1XqOSuKMpeQ$
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
More information about the QGIS-PSC
