[Qgis-psc] Qt6 status
Matthias Kuhn
matthias at opengis.ch
Fri Aug 22 08:29:42 PDT 2025
Hi all,
Nice to see the progress on the ci front, thanks Nyall.
The Qt6 packages for Windows and macOS are also ready to be tested as well
(thanks Jürgen).
I suspect many developers do most of their work with Qt5 (because it's more
efficient looking at the build times) and therefore most testing by core
developers and technical people is done on Qt5 builds.
One thing that could help is to change the default to BUILD_WITH_QT6 as
soon as possible and collect some low hanging fruits.
With the feature freeze less than 3 weeks in front of us and the release in
about two months, I think it's a good point to check if we are on track
with the timeline or if we want to consider an adjustment as pointed out by
Marco earlier in this thread.
Cheers
Matthias
On Fri, Aug 22, 2025 at 9:11 AM Alessandro Pasotti via QGIS-PSC <
qgis-psc at lists.osgeo.org> wrote:
> I am currently on vacation but I will have a look next week.
> Kind regards
> Alessandro Pasotti
> QCooperative: www.qcooperative.net
> ItOpen: www.itopen.it
> Il gio 21 ago 2025, 11:22 Marco Bernasocchi via QGIS-PSC <
> qgis-psc at lists.osgeo.org> ha scritto:
>> Thanks Nyall for the work and answer.
>> on the other two points,
>> - having some solution for the extremely slow sip build times on qt6
>> Martin, do you have an ETA for David's grant https://github.com/qgis/QGIS-Enhancement-Proposals/pull/338
>> - porting the ogc server ci to qt6
>> Alessandro, would that be something you'd be willing/would have time ressources to take over since you worked a lot on the server in the past?
>> it would be great if we can move all this forward so we can come closer to a qgis 4.0.
>> I'd also would like to re ask if we should start preparing for a 1(x?) month delay for the freeze? And remember that there are funding available.
>> Cheers
>> Marco
>> On Fri, 8 Aug 2025 at 05:22, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> On Fri, 8 Aug 2025 at 04:11, Marco Bernasocchi <marco at qgis.org> wrote:
>>> > Hi all,
>>> > I was just pointed to this mail
>>> > https://lists.osgeo.org/pipermail/qgis-developer/2025-July/067716.html
>>> > and noticed that Nyall mentions some still needed work.
>>> > @Nyall, do you think the freeze in 5 weeks is realistic? Do we need to
>>> plan/prepare something different?
>>> > Please, all developer involved in moving to Qt6, that the psc still
>>> has reserved funding for this.
>>> - porting the Ubuntu ci infrastructure to qt6, including the database
>>> server based tests
>>> I'm currently working on this -- see
>>> https://github.com/qgis/QGIS/pull/62809
>>> Nyall
>>> > Cheers Marco
>>> > Marco Bernasocchi
>>> > QGIS.org Chair
>>> > OSGEO.org VP Europe
>>> > OPENGIS.ch CEO
>>> > http://berna.io
>> Marco Bernasocchi
>> QGIS.org Chair
>> OSGEO.org VP Europe
>> OPENGIS.ch CEO
>> http://berna.io
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20250822/3d8c5552/attachment.htm>
More information about the QGIS-PSC
