[Qgis-psc] Progress on SIP incremental build grant
Jean Felder
jean.felder at oslandia.com
Mon Dec 8 08:10:51 PST 2025
Hi David,
I have just installed sip 6.15 which contains your work from [3] and sip
is much faster now.
Thank you for working on this.
Jean
Le 09/10/2025 à 10:46, David Koňařík via QGIS-PSC a écrit :
> Hi all,
> I'd like to share with you a report of the work I did on QEP 338 (SIP
> incremental builds):
> My original plan was to build each header file as a separate binding,
> then use SIP from a Python script, overriding a few methods to allow
> building just one binding out of a project.
> After a lot of effort, this plan sadly doesn't seem workable. PyQt's
> bindings aren't modularised enough, so building a single binding still
> needs to parse almost all of PyQt. Furthermore, SIP has a multi-stage
> parse-resolve-generate design, but the "parser" does more than just
> parse the code into an AST, not all references are resolved in the
> resolve phase, and imports are currently basically done by textual
> inclusion.
> I've tried making the necessary changes to SIP [1] and QGIS [2], but
> for the above reasons, I don't think the performance benefits for
> single-file builds are worth the added complexity and performance
> penalty for clean builds (which look to be over an hour currently).
> The good news is that with the knowledge from working on SIP, I've
> been able to improve the performance of regular clean builds, and
> those improvements might soon be merged into SIP itself [3]. I've also
> made some changes on the QGIS side to not rebuild unchanged code
> generated by SIP [4]. With code compilation now taking longer than SIP
> code generation, this effectively gives us incremental builds, just at
> a larger granularity.
> David Koňařík
> [1]: https://github.com/dvdkon/sip/tree/qgis-gb
> [2]: https://github.com/dvdkon/QGIS/tree/sip-incremental-build
> [3]: https://github.com/Python-SIP/sip/pull/87
> [4]: https://github.com/qgis/QGIS/pull/63160
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Jean Felder
Développeur SIG
Oslandia
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20251208/8517cbef/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20251208/8517cbef/attachment.sig>
More information about the QGIS-PSC
