[Qgis-psc] Qt6 status
Marco Bernasocchi marco at qgis.org
Mon Sep 1 12:40:17 PDT 2025
Hi All,
thanks a lot for all the feedback.
we're discussing this in the PSC and will get right ASAP.
Cheers Marco
On Mon, 25 Aug 2025 at 15:55, Julien Cabieces via QGIS-PSC <
qgis-psc at lists.osgeo.org> wrote:
> Hi,
> Regarding the current situation, I would also be in favor of postponing
> the QGIS 4.0 release.
> Regards,
> Julien
> > On Sat, 23 Aug 2025 at 19:35, Mathieu Pellerin via QGIS-PSC
> > <qgis-psc at lists.osgeo.org> wrote:
> >> With regards to the timeline question raised by Marco in this
> >> thread, I'd like to add a +1 to the idea of postponing QGIS 4.0. At
> >> the very least, I think we should make a conscious decision about it
> >> sooner than later :)
> > I'm also +1 to deferring QGIS 4.0 for one release cycle. (ie skip
> > October's release, and release 4.0 in February).
> > The CI port to Qt 6 is basically ready now (at
> > https://github.com/qgis/QGIS/pull/62809). However -- there's still a
> > handful of tests which pass under Qt 5 which are skipped on the Qt 6
> > builds right now, and this makes me nervous. If we merged #62809 today
> > and moved exclusively to Qt 6 then we'll lose some test coverage. I'd
> > prefer to hold off merging #62809 until we can get these remaining
> > tests passing on the ubuntu qt6 builds.
> > Hopefully that's just a matter of days, not weeks!
> > Nyall
> >> While we should all be very proud of the regular release interval
> discipline we've shown in recent years, I think several factors warrant at
> least seriously considering delaying QGIS 4.0.
> >> Like Matthias, I believe the fact that a Qt6-based development
> >> environment not adding a *considerable* amount of time spent
> >> building not having been unlocked yet means most of our developers
> >> are still on Qt5. On my end, I did try to switch to a Qt6-only
> >> development environment during the last freeze period, only to find
> >> myself going back to Qt5 to retain an acceptable build wait
> >> time. While we have had Qt6-based CI testing going on for a while
> >> and being improved week after week, I would feel really insecure
> >> shipping QGIS 4.0 with Qt6 libraries when most devs have not spent a
> >> fair amount of time running Qt6 builds (both as part of their
> >> development as well as mapping production environments). We're also
> >> a few weeks away from bug fixing, and we risk entering it with
> >> developers still fixing bugs against Qt5 libraries (because it's
> >> that much more efficient).
> >> On top of what has been raised above, something less crucial but
> >> that is still worth factoring in: we had a couple of interesting
> >> changes we wanted to push into QGIS 4.0 which at the moment are
> >> increasingly at risk of not making it into an October release
> >> date. For example, at this moment in time, I'm certain the icons set
> >> revamp proposition can't be achieved in time. It'd be good to hear
> >> the status of other important changes like the welcome screen
> >> revamp.
> >> Beyond that, thanks for the status updates and ongoing efforts to all
> involved! Keen to hear what others have to say about this.
> >> Mathieu
> >> On Fri, Aug 22, 2025 at 10:30 PM Matthias Kuhn via QGIS-PSC <
> >>> Hi all,
> >>> Nice to see the progress on the ci front, thanks Nyall.
> >>> The Qt6 packages for Windows and macOS are also ready to be tested as
> well (thanks Jürgen).
> >>> I suspect many developers do most of their work with Qt5 (because it's
> more efficient looking at the build times) and therefore most testing by
> core developers and technical people is done on Qt5 builds.
> >>> One thing that could help is to change the default to BUILD_WITH_QT6
> as soon as possible and collect some low hanging fruits.
> >>> With the feature freeze less than 3 weeks in front of us and the
> >>> release in about two months, I think it's a good point to check if
> >>> we are on track with the timeline or if we want to consider an
> >>> adjustment as pointed out by Marco earlier in this thread.
> >>> Cheers
> >>> Matthias
> >>> On Fri, Aug 22, 2025 at 9:11 AM Alessandro Pasotti via QGIS-PSC <
> >>>> I am currently on vacation but I will have a look next week.
> >>>> Kind regards
> >>>> Alessandro Pasotti
> >>>> QCooperative:  www.qcooperative.net
> >>>> ItOpen:   www.itopen.it
> >>>> Il gio 21 ago 2025, 11:22 Marco Bernasocchi via QGIS-PSC <
> qgis-psc at lists.osgeo.org> ha scritto:
> >>>>> Thanks Nyall for the work and answer.
> >>>>> on the other two points,
> >>>>> - having some solution for the extremely slow sip build times on qt6
> >>>>> Martin, do you have an ETA for David's grant
> https://github.com/qgis/QGIS-Enhancement-Proposals/pull/338
> >>>>> - porting the ogc server ci to qt6
> >>>>> Alessandro, would that be something you'd be willing/would have time
> ressources to take over since you worked a lot on the server in the past?
> >>>>> it would be great if we can move all this forward so we can come
> closer to a qgis 4.0.
> >>>>> I'd also would like to re ask if we should start preparing for a
> 1(x?) month delay for the freeze? And remember that there are funding
> available.
> >>>>> Cheers
> >>>>> Marco
> >>>>> On Fri, 8 Aug 2025 at 05:22, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
> >>>>>> On Fri, 8 Aug 2025 at 04:11, Marco Bernasocchi <marco at qgis.org>
> wrote:
> >>>>>> > Hi all,
> >>>>>> > I was just pointed to this mail
> https://lists.osgeo.org/pipermail/qgis-developer/2025-July/067716.html
> >>>>>> > and noticed that Nyall mentions some still needed work.
> >>>>>> > @Nyall, do you think the freeze in 5 weeks is realistic? Do we
> need to plan/prepare something different?
> >>>>>> > Please, all developer involved in moving to Qt6, that the psc
> still has reserved funding for this.
> >>>>>>  - porting the Ubuntu ci infrastructure to qt6, including the
> database
> >>>>>> server based tests
> >>>>>> I'm currently working on this -- see
> >>>>>> Nyall
> >>>>>> > Cheers Marco
> >>>>>> > Marco Bernasocchi
> >>>>>> > QGIS.org Chair
> >>>>>> > OSGEO.org VP Europe
> >>>>>> > OPENGIS.ch CEO
> >>>>>> > http://berna.io
> >>>>> Marco Bernasocchi
> >>>>> QGIS.org Chair
> >>>>> OSGEO.org VP Europe
> >>>>> OPENGIS.ch CEO
> >>>>> http://berna.io
> >>>>> _______________________________________________
> >>>>> QGIS-PSC mailing list
> >>>>> QGIS-PSC at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Julien Cabieces
> Senior Developer at Oslandia
> julien.cabieces at oslandia.com
Marco Bernasocchi
QGIS.org Chair
OSGEO.org VP Europe
OPENGIS.ch CEO
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20250901/9ba2b136/attachment.htm>
More information about the QGIS-PSC mailing list
