[Qgis-psc] QGIS. org site Wordpres theme.
Andreas Neumann andreas at qgis.org
Tue Sep 9 00:19:30 PDT 2025
Hi Michal,
It is up to you to decide. But I would not recommend using Wordpress
really. Wordpress is known for its many vulnerabilities and needs permanent
maintenance. Unless you go for a "hosted" solution where you shuffle off
the responsibility to someone else.
Today I would opt for a solution based on md (markdown) files and templates
- and a static site generator. You could have a git repo where the authors
check in their markdown files and a Github action rebuilds and deploys the
static site.
QGIS itself is using Hugo for this purpose, in my day project (Atlas of
Switzerland) we are using Astro. See https://gohugo.io/ and
https://astro.build/ - the QGIS user group Switzerland is using Jekyll (
https://jekyllrb.com/).
But finally it is up to you to decide. The site generators may be more
complicated to start, but after that investment was made, it pays off by
having a more secure solution than Wordpress.
Greetings,
Andreas
On Tue, 9 Sept 2025 at 08:47, Michał Drożdż via QGIS-PSC <
qgis-psc at lists.osgeo.org> wrote:
> Hi all!
> In the Polish QGIS user group, we are planning to renew our website. We
> would like to use a modern template created last year. We are testing it,
> but there is no CMS behind it. Adding a new blog post requires programming
> skills, which is a significant obstacle.
> We are considering commissioning the development of a WordPress template
> based on the current QGIS.org website. This template could then be used by
> other user groups as well.
> Has the topic of using WordPress been discussed? Are there any drawbacks
> to this solution?
> *Michał Drożdż*
> Prezes Zarządu
> tel: +48 888 200 115
> GIS Support Sp. z o.o.
> Konrada Wallenroda 2f, Lublin 20-607
> <https://maps.google.com/?q=Konrada+Wallenroda+2f,+Lublin+20-607>
> tel. +48 570 979 682, NIP: 9462641761
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Andreas Neumann
QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20250909/a4454736/attachment-0001.htm>
More information about the QGIS-PSC mailing list
