[Qgis-psc] Realistically, we can't release in 2 days 😱
Régis Haubourg regis at qgis.org
Wed Feb 18 04:21:11 PST 2026
Hi all,
I support the idea of fixing this one before releasing. A bug that
destroys other profiles that are used for production is a real no-go,
that would be unprofessional to release this, even with warnings. Not
everyone keeps its profile under version control :)
Best regards,
Régis Haubourg
Elected member at the Program Steering Comitee of QGIS.org.
On 18/02/2026 08:52, Richard Duivenvoorde via QGIS-PSC wrote:
> On 2/18/26 05:05, Nyall Dawson via QGIS-PSC wrote:
>> Hey list,
>> Everyone who has been actively testing 4.0 nightlies has probably
>> seen this coming, but we're just NOT ready to publicly release 4.0 on
>> the 20th. Aside from anything else, we still don't have a fix for the
>> profile corruption bug* which should be a blocker alone. With this
>> one a user's 3.x profile can get completely corrupted, and/or cause
>> hangs on loading 3.x/4.0.
>> What should we do?
> As a heavy profile user (>25 profiles; why is OpenActiveProfile folder
> at the bottom anyway :-)), AND someone switching between QGIS versions
> a lot(!), I prefer to fix this first... Seems a real blocker to me :-(
> Just wondering, after reading https://github.com/qgis/QGIS/pull/64752:
> is this only about the encoding of
> ~/.local/share/QGIS/QGIS3/profiles/<ALL PROFILES>/QGIS/QGIS3.ini   ?
> or also about the (encoding? of) other files in the profile folder?
> You probably looked, but IF only about the ini file, it's not possible
> to create a QGIS4.ini (or just QGIS.ini) only
> ~/.local/share/QGIS/QGIS3/profiles/<ALL PROFILES>/QGIS/QGIS4.ini   ?
> But I reckon you are right :-)
> So we copy the full profiles folder to
> ~/.local/share/QGIS/QGIS4/profiles/<ALL PROFILES>/QGIS/QGIS4.ini  ?
> Doing that once, yes?
> Is there maybe an easy way to check (after the one-time copy) if a
> QGIS3 profile is newer then (or updated) the QGIS4 profile? And IF so
> let the user decide if we want to 'refresh/copy' the QGIS3->QGIS4 (1
> profile folder) again?
> I'm thinking about peeps like me, who probably have to work some time
> in QGIS3 (because certain clients will stick to 3.40 or 3.44 for some
> time).
> Anyway: THANKS for feeling responsible for this!
> Regards,
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the QGIS-PSC mailing list
