[Qgis-psc] Grant report: Restore the print layout HTML item for QGIS 4
Régis Haubourg regis at qgis.org
Tue Nov 17 02:21:31 PST 2026
Thanks Nyall !
Best regards,
Régis Haubourg
Elected member at the Program Steering Comitee of QGIS.org.
On 17/11/2026 05:47, Nyall Dawson wrote:
> On Sat, 14 Nov 2026 at 03:10, Régis Haubourg via QGIS-PSC
> <qgis-psc at lists.osgeo.org> wrote:
>> Hi Nyall, well done !
>> I'm really happy this blocker is workaround for QGIS 4.
>> This seems to have been a giant task.
>> We will have to document clearly the QGIS's network bypassing for corporate users that really care about this.
>> Is there a way to change user agent and proxy settings for the webengine ?
> I've done the user agent inhttps://github.com/qgis/QGIS/pull/68221 ,
> now it'll inherit QGIS' standard user agent.
> For proxies, it turns out that qt does reuse SOME of the proxy
> settings automatically. (What won't work is authenticated proxies)
> Nyall
>> Best regards,
>> Régis Haubourg
>> On 13/11/2026 05:34, Nyall Dawson via QGIS-PSC wrote:
>> Hi PSC,
>> I'm happy to report that following the grant "Restore the print layout
>> HTML item for QGIS 4"
>> (https://github.com/qgis/QGIS-Enhancement-Proposals/pull/377), the
>> print layout HTML item has now been resurrected for QGIS 4.4!
>> This was a heavy undertaking, involving many different parts. The
>> upstream removal of the QtWebkit support and replacement by the
>> less-featured (but more modern and secure) webengine framework
>> completely removed the API we were relying on for rendering the HTML
>> print layout item.
>> No direct replacement API was available for rendering webengine
>> content in high quality, vector formats. To work around this, I've
>> implemented a complicated approach that uses webengine's print
>> capabilities to export vectorised HTML content to a PDF file, and then
>> the PDF4QT library to render this into the layout HTML item.
>> Via this approach I've been able to resurrect almost all the
>> functionality that the item had under QGIS 3, including support for
>> user stylesheets, and injection of atlas feature json into the HTML.
>> Additionally, I took the opportunity to fix a long-standing
>> performance issue relating to the HTML item. In QGIS 3, the HTML
>> content would always be loaded and rendered immediately, in the main
>> thread, when creating the item. This also occurred whenever a QGIS
>> project was loaded that contained a HTML item, resulting in very slow
>> load times for these projects! Furthermore, all the HTML rendering was
>> always done on the GUI thread, so navigating and interacting with
>> layouts containing HTML content was slow and would result in many QGIS
>> pauses.
>> Now, all the loading and rendering is done asynchronously. The HTML
>> fetching and rendering will only happen when required (no longer at
>> project load time!), and now happens in a background thread so that
>> the layout designer always remains responsive to work with.
>> That said, there remains some regressions which users should be aware
>> of when compared with the HTML item support in QGIS 3:
>> - The webengine backend uses its own independent networking library,
>> which is not integrated in any way with the networking library used by
>> the rest of QGIS. Accordingly, the HTML item will ignore the proxy,
>> SSL, cache, user agent, authentication and other QGIS network
>> settings. Requests won't be shown in the QGIS Network logger panel
>> either. QGIS administrators will need to be aware of this and adjust
>> their network's firewall settings accordingly.
>> - While the HTML content is always rendered as high-quality vectors,
>> text from the HTML will always be converted to paths. This looks
>> identical, but means that text from the HTML item in  PDF or SVG
>> exported layouts won't be selectable, searchable, or editable. (It's
>> possible that this limitation may be fixable in follow-up work)
>> - HTML content will render slightly larger than in QGIS 3 (around 10%
>> larger). This is a feature, not a bug! The original webkit library
>> incorrectly sized the HTML content, as reported in
>> https://github.com/qgis/QGIS/issues/19901. Now, the font and css sizes
>> from the HTML content will be an exact match for font and other sizes
>> for non-HTML layout items. Users may need to adjust their HTML or CSS
>> to adjust for this sizing difference when loading older projects into
>> QGIS 4.
>> Thanks to the QGIS project and all donors for funding this work and
>> restoring this valuable capability!
>> (The final part of this work is currently waiting review at
>> https://github.com/qgis/QGIS/pull/68161)
>> Nyall
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
>> ⁣‌‍⁣-- INSERT --⁣‌‍⁣87,0-1 Bot
⁣‌‍⁣-- INSERT --⁣‌‍⁣116,0-1 Bot
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20261117/e23e4794/attachment.htm>
More information about the QGIS-PSC mailing list
