[QGIS-pt] Boas
Alexandre Neto senhor.neto gmail.com
Quarta-Feira, 17 de Dezembro de 2014 - 15:06:12 PST
Aqui vai a resposta do Nyall.
Aparentemente a implementação do CMYK terá de ser feita primeiro no Qt (que
é a framework sobre a qual o qgis está criado).
E ao que parece os últimos pedidos nesse sentido não surtiram grande
efeito. Não sabemos se no caso do Qt é possível patrocinar este tipo de
melhorias.
On 18 December 2014 at 01:31, Alexandre Neto <senhor.neto  gmail.com>
wrote:>> Hello everyone,>> Does anyone know if there are any plans for
implementing CMYK color mode in> QGIS?I did a bit of research yesterday and
it looks like we're out of luckuntil the underlying Qt libraries (QPainter,
QPrinter, QtSvg) gainsupport for CMYK. We could add support for selecting
CMYK colours intothe new colour picker, but currently all of the export
optionsavailable in Qt convert colours back to RGB prior to export.> If
there are no plans for that, can someone give me anideia of what would>
need to be done?It would need to be implemented in Qt, but I can't find
muchinformation about whether this is planned or not. Here's a couple
ofrelevant reports (with almost zero activity):
https://bugreports.qt-project.org/browse/QTBUG-896https://bugreports.qt-project.org/browse/QTBUG-86https://bugreports.qt-project.org/browse/QTBUG-21276I'm
also not sure if Qt has a culture of sponsored targeteddevelopment, or who
you could get to tackle this... I'm interested toknow any findings you have
though, as there's a number of similar Qtlimitations which really hold us
back:
https://bugreports.qt-project.org/browse/QTBUG-28636https://bugreports.qt-project.org/browse/QTBUG-36302https://bugreports.qt-project.org/browse/QTBUG-6582(also
there's a report that I can't find right now about allowingediting of PDF
metadata)Nyall
Em 16/12/2014 07:21, "Luigi Pirelli" <luipir  gmail.com> escreveu:
> Hola Alexander,
> envia el correo tambien en qgis-developer para fomentar la discusión
> ciao Luigi Pirelli
> 2014-12-16 0:46 GMT+01:00 Alexandre Neto <senhor.neto  gmail.com>:
>> Boa noite,
>> Já mandei um email ao Nyall a saber se existem planos para a introdução
>> do CMYK no QGIS, e o que seria preciso para o implementar.
>> Vamos ver o que ele responde.
>> Abraço,
>> Alexandre Neto
>> 2014-12-15 19:34 GMT+00:00 Vinicius Silva <x3msnake  gmail.com>:
>>> Aqui está mais uma biblioteca que tem muito potencial, se integrada com
>>> o Qgis
>>> [image: Tree]
>>> http://xxyxyz.org/flat
>>> No dia 15 de dezembro de 2014 às 19:30, Vinicius Silva <
>>> x3msnake  gmail.com> escreveu:
>>>> Boas Luigi
>>>> Encontrei uma biblioteca de gestão de cores que penso pode ser um meio
>>>> para acelerar o processo de criação de um Plug ou integração do CMYK no
>>>> http://www.cazabon.com/pyCMS/
>>>> http://unix.stackexchange.com/questions/22193/how-can-i-generate-cmyk-images-via-the-command-line-under-linux
>>>> Vou então perguntar no freenode. Thanks
>>>> Abraços Master Luigi
>>>> No dia 15 de dezembro de 2014 às 18:45, Luigi Pirelli <luipir  gmail.com
>>>> > escreveu:
>>>>> Hola vinicius, el paso es ir al irc de freenode #qgis y preguntar allí
>>>>> en inglés, creo que marco y nyall te pueden decir exactamente la parte de
>>>>> código relacionada con cmyk.
>>>>> Esto para empezar... Y después en qgis-developer que seguro hay
>>>>> personas interesadas. Cuenta que seguro puede crear un pledge para
>>>>> financiarte el desarrollo.
>>>>> Cual Luigi Pirelli
>>>>> On Monday, 15 December 2014, Hugo <hfpmartins  gmail.com> wrote:
>>>>>> Olá Vinicius,
>>>>>> Bem vindo...
>>>>>> Vamos esperar a ver se o Alex sabe onde isso está. Caso contrário
>>>>>> logo te ajudo a encontrar esse pedaço de código.
>>>>>> O plugin pode ser uma ideia... mas fixe fixe era isso entrar para o
>>>>>> core do QGIS. O Alex ficou de falar com o developer que anda mais activo
>>>>>> nessa componente para saber como está a coisa. Vamos esperar um pouco pelo
>>>>>> feedback.
>>>>>> Grande abc,
>>>>>> No dia 15 de dezembro de 2014 às 14:05, Vinicius Silva <
>>>>>>> Boas Pessoal
>>>>>>> Já cá estou inscrito ;)
>>>>>>> Em que parte ou partes do Source Code do Qgis está o sistema de
>>>>>>> cores?
>>>>>>> Gostava de dar uma vista de olhos para tentar compreender se será
>>>>>>> muito difícil adaptar o sistema para usar cores CMYK em vez das cores de
>>>>>>> sistema.
>>>>>>> Caso contrario poderia-se produzir um plugin de exportação que
>>>>>>> identifique as cores utilizadas e permita ao utilizador indicar quais as
>>>>>>> cores.
>>>>>>> Seria interessante ter exportação para PDF em CMYK Georeferenciado
>>>>>>> Com os melhores cumprimentos,
>>>>>>> Vinicius Silva
>>>>>>> _______________________________________________
>>>>>>> QGIS-pt mailing list
>>>>>>> QGIS-pt  lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/qgis-pt
>>>>>> Hugo Martins
>>>> Vinicius Silva
>>> Vinicius Silva
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20141217/53bd855d/attachment.html>
More information about the QGIS-pt mailing list
