[QGIS-pt] Erro no corte de raster ["Clip Raster by Mask Layer"]
Valter Albino valteralbino at gmail.com
Thu Feb 13 13:52:07 PST 2020
Viva
Tentei fazer um recorte através de função "Clip Raster by Mask Layer" pelo
menu do QGIS, mas sem sucesso.
Sabem o que poderá ser?
Anexo mensagem:
QGIS version: 3.10.2-A Coruña
QGIS code revision: d4cd3cfe5a
Qt version: 5.11.2
GDAL version: 3.0.4
GEOS version: 3.8.0-CAPI-1.13.1
PROJ version: Rel. 6.3.0, January 1st, 2020
Processing algorithm…
Algorithm 'Clip raster by mask layer' starting…
Input parameters:
{ 'ALPHA_BAND' : True, 'CROP_TO_CUTLINE' : True, 'DATA_TYPE' : 0, 'EXTRA' :
'', 'INPUT' :
'H:/FICHEIROS_DADOS/OT&U/ORDENAMENTO_TERRITORIO/PLANOS_DESENVOLV_TERRIT/PSECT/PROF/PROF_LVT/PROF_LVT/DISCPUBL/PROF_LVT_pecas_graficas/PG_3_AreasFlorestaisSensiveis_e_CE_LVT_3-5.jpeg',
'KEEP_RESOLUTION' : False, 'MASK' :
'Polygon?crs=EPSG:3763&uid={f2fbc031-7884-4446-a21f-2630b2d88616}',
'MULTITHREADING' : False, 'NODATA' : None, 'OPTIONS' : '', 'OUTPUT' :
'TEMPORARY_OUTPUT', 'SET_RESOLUTION' : False, 'SOURCE_CRS' : None,
'TARGET_CRS' : None, 'X_RESOLUTION' : None, 'Y_RESOLUTION' : None }
GDAL command:
gdalwarp -of GTiff -cutline
C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/30b1cf7e549d459a82bba50fa23ed1a7/MASK.gpkg
-cl MASK -crop_to_cutline -dstalpha
C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif
GDAL command output:
FAILURE: No target filename specified.
Usage: gdalwarp [--help-general] [--formats]
[-s_srs srs_def] [-t_srs srs_def] [-to "NAME=VALUE"]* [-novshiftgrid]
[-order n | -tps | -rpc | -geoloc] [-et err_threshold]
[-refine_gcps tolerance [minimum_gcps]]
[-te xmin ymin xmax ymax] [-tr xres yres] [-tap] [-ts width height]
[-ovr level|AUTO|AUTO-n|NONE] [-wo "NAME=VALUE"] [-ot Byte/Int16/...] [-wt
Byte/Int16]
[-srcnodata "value [value...]"] [-dstnodata "value [value...]"] -dstalpha
[-r resampling_method] [-wm memory_in_mb] [-multi] [-q]
[-cutline datasource] [-cl layer] [-cwhere expression]
[-csql statement] [-cblend dist_in_pixels] [-crop_to_cutline]
[-of format] [-co "NAME=VALUE"]* [-overwrite]
[-nomd] [-cvmd meta_conflict_value] [-setci] [-oo NAME=VALUE]*
[-doo NAME=VALUE]*
srcfile* dstfile
Available resampling methods:
near (default), bilinear, cubic, cubicspline, lanczos, average, mode, max,
min, med, Q1, Q3.
'U' is not recognized as an internal or external command,
operable program or batch file.
Execution completed in 0.31 seconds
Results:
{'OUTPUT':
'C:\\Users\\PARTIC~1\\AppData\\Local\\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif'}
Loading resulting layers
The following layers were not correctly
generated.<ul><li>C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif</li></ul>You
can check the 'Log Messages Panel' in QGIS main window to find more
information about the execution of the algorithm.
Obrigado desde já
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20200213/2987b6d8/attachment.html>
More information about the QGIS-pt mailing list
