[QGIS-pt] Erro no corte de raster ["Clip Raster by Mask Layer"]
Valter Albino valteralbino at gmail.com
Thu Feb 13 14:38:45 PST 2020
Correção, queria escrever "caractere"
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Valter Albino <valteralbino  gmail.com> escreveu no dia quinta, 13/02/2020
à(s) 22:34:
> Bom... AFAIK, é mesmo somente o caratere especial que estava a corromper:
> QGIS version: 3.10.2-A Coruña
> QGIS code revision: d4cd3cfe5a
> Qt version: 5.11.2
> GDAL version: 3.0.4
> GEOS version: 3.8.0-CAPI-1.13.1
> PROJ version: Rel. 6.3.0, January 1st, 2020
> Processing algorithm…
> Algorithm 'Clip raster by mask layer' starting…
> Input parameters:
> { 'ALPHA_BAND' : False, 'CROP_TO_CUTLINE' : True, 'DATA_TYPE' : 0, 'EXTRA'
> : '', 'INPUT' :
> 'H:/FICHEIROS_DADOS/OTU/ORDENAMENTO_TERRITORIO/PLANOS_DESENVOLV_TERRIT/PSECT/PROF/PROF_LVT/PROF_LVT/MASCARA_folha3_5/PG_3_AreasFlorestaisSensiveis_e_CE_LVT_3-5_clip.tif',
> 'KEEP_RESOLUTION' : False, 'MASK' :
> 'Polygon?crs=EPSG:3763&uid={66c596a4-5d98-4c6b-a664-c988783e6b41}',
> 'MULTITHREADING' : False, 'NODATA' : None, 'OPTIONS' : '', 'OUTPUT' :
> 'TEMPORARY_OUTPUT', 'SET_RESOLUTION' : False, 'SOURCE_CRS' : None,
> 'TARGET_CRS' : None, 'X_RESOLUTION' : None, 'Y_RESOLUTION' : None }
> GDAL command:
> gdalwarp -of GTiff -cutline
> C:\Users\PARTIC~1\AppData\Local\Temp/processing_73997acac74c4ed9b0ea6749fcf6c93c/7e0afb402fce4ce8b1e7ba242101ad18/MASK.gpkg
> -cl MASK -crop_to_cutline
> C:\Users\PARTIC~1\AppData\Local\Temp/processing_73997acac74c4ed9b0ea6749fcf6c93c/2dd6cfcbb5524ca7bc6dfea0c9269515/OUTPUT.tif
> GDAL command output:
> Creating output file that is 944P x 590L.
> Processing
> [1/1] : 0Using internal nodata values (e.g. 65535) for image
> H:/FICHEIROS_DADOS/OTU/ORDENAMENTO_TERRITORIO/PLANOS_DESENVOLV_TERRIT/PSECT/PROF/PROF_LVT/PROF_LVT/MASCARA_folha3_5/PG_3_AreasFlorestaisSensiveis_e_CE_LVT_3-5_clip.tif.
> Copying nodata values from source
> to destination
> C:\Users\PARTIC~1\AppData\Local\Temp/processing_73997acac74c4ed9b0ea6749fcf6c93c/2dd6cfcbb5524ca7bc6dfea0c9269515/OUTPUT.tif.
> ...10...20...30...40...50...60...70...80...90...100 - done.
> Execution completed in 0.40 seconds
> Results:
> {'OUTPUT':
> 'C:\\Users\\PARTIC~1\\AppData\\Local\\Temp/processing_73997acac74c4ed9b0ea6749fcf6c93c/2dd6cfcbb5524ca7bc6dfea0c9269515/OUTPUT.tif'}
> Loading resulting layers
> Algorithm 'Clip raster by mask layer' finished"
> Obrigado.
> Cumprimentos,
> à(s) 22:25:
>> Olá Bruno,
>> Bem esta foi uma daquelas Q&A bem básicas.
>> Obrigado, parece que o caminho era extenso demais :-)
>> Cumprimentos,
>> Bruno Moreira <arq.bruno.moreira  gmail.com> escreveu no dia quinta,
>> 13/02/2020 à(s) 22:18:
>>> Poderá ser o caminho do ficheiro de entrada (a pasta OT&U contém um
>>> símbolo, por norma penso ser de os evitar; o caminho também é muito longo).
>>> Sugeria mover o raster para, por exemplo, a raiz do disco em C:  e
>>> tentar novamente, para despistar.
>>> Bruno Moreira
>>> No dia 13/02/2020, às 21:52, Valter Albino <valteralbino  gmail.com>
>>> escreveu:
>>> Viva
>>> Tentei fazer um recorte através de função "Clip Raster by Mask Layer"
>>> pelo menu do QGIS, mas sem sucesso.
>>> Sabem o que poderá ser?
>>> Anexo mensagem:
>>> Qt version: 5.11.2
>>> GDAL version: 3.0.4
>>> Input parameters:
>>> { 'ALPHA_BAND' : True, 'CROP_TO_CUTLINE' : True, 'DATA_TYPE' : 0,
>>> 'EXTRA' : '', 'INPUT' :
>>> 'H:/FICHEIROS_DADOS/OT&U/ORDENAMENTO_TERRITORIO/PLANOS_DESENVOLV_TERRIT/PSECT/PROF/PROF_LVT/PROF_LVT/DISCPUBL/PROF_LVT_pecas_graficas/PG_3_AreasFlorestaisSensiveis_e_CE_LVT_3-5.jpeg',
>>> 'Polygon?crs=EPSG:3763&uid={f2fbc031-7884-4446-a21f-2630b2d88616}',
>>> GDAL command:
>>> C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/30b1cf7e549d459a82bba50fa23ed1a7/MASK.gpkg
>>> -cl MASK -crop_to_cutline -dstalpha
>>> C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif
>>> FAILURE: No target filename specified.
>>> Usage: gdalwarp [--help-general] [--formats]
>>> [-s_srs srs_def] [-t_srs srs_def] [-to "NAME=VALUE"]* [-novshiftgrid]
>>> [-order n | -tps | -rpc | -geoloc] [-et err_threshold]
>>> [-refine_gcps tolerance [minimum_gcps]]
>>> [-te xmin ymin xmax ymax] [-tr xres yres] [-tap] [-ts width height]
>>> [-ovr level|AUTO|AUTO-n|NONE] [-wo "NAME=VALUE"] [-ot Byte/Int16/...]
>>> [-wt Byte/Int16]
>>> [-srcnodata "value [value...]"] [-dstnodata "value [value...]"] -dstalpha
>>> [-r resampling_method] [-wm memory_in_mb] [-multi] [-q]
>>> [-cutline datasource] [-cl layer] [-cwhere expression]
>>> [-csql statement] [-cblend dist_in_pixels] [-crop_to_cutline]
>>> [-of format] [-co "NAME=VALUE"]* [-overwrite]
>>> [-nomd] [-cvmd meta_conflict_value] [-setci] [-oo NAME=VALUE]*
>>> [-doo NAME=VALUE]*
>>> srcfile* dstfile
>>> Available resampling methods:
>>> near (default), bilinear, cubic, cubicspline, lanczos, average, mode,
>>> max, min, med, Q1, Q3.
>>> 'U' is not recognized as an internal or external command,
>>> operable program or batch file.
>>> Execution completed in 0.31 seconds
>>> Results:
>>> {'OUTPUT':
>>> 'C:\\Users\\PARTIC~1\\AppData\\Local\\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif'}
>>> The following layers were not correctly
>>> generated.<ul><li>C:\Users\PARTIC~1\AppData\Local\Temp/processing_34d70197907049729d4ea29a9111efd2/57d22bdf9eaa4afba7e5c33a72c3685a/OUTPUT.tif</li></ul>You
>>> can check the 'Log Messages Panel' in QGIS main window to find more
>>> information about the execution of the algorithm.
>>> Obrigado desde já
>>> Cumprimentos,
>>> QGIS-pt mailing list
>>> QGIS-pt  lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-pt
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/qgis-pt/attachments/20200213/16954a00/attachment-0001.html>
More information about the QGIS-pt mailing list
