[qgis-qwc2] Status check qwc2
Sandro Mani manisandro at gmail.com
Thu Aug 24 06:43:31 PDT 2017
On 24.08.2017 14:17, Karl Magnus Jönsson wrote:
> Thanks for a really fast answer. I’ve come up with to more questions:
> ·Invit did some work on the client for redlining. There is still need
> for extend the server API to render this for printing. I suppose it’s
> not in the plans for this fall. Is it much work to do? And who can do it?
Some work on redlining is planned, need to check about printing.
> ·Would it be possible to use the one request for each layer approach
> without having to rebuild the whole client?
One could implement it as a configurable setting, say a switch in
config.json, so that you can toggle it without needing to rebuild the
application bundle.
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20170824/f814a216/attachment.html>
More information about the qgis-qwc2 mailing list
