[qgis-qwc2] Question about Editin Plugin
Sandro Mani manisandro at gmail.com
Thu Apr 26 02:02:28 PDT 2018
Hi Sebastian
Your themes.json works here (resp I can see "Natur in der Stadt" as
editable layer).
Are you sure the themes.json the client is reading contains the editConfig?
The matching between the layer names in the editConfig and the actual
WMS names is only important to ensure the WMS layers are correctly
refreshed after edit changes are committed. The "No editable layers
found" message really only appears when the editConfig is empty.
Best
Sandro
On 25.04.2018 10:29, GOERKE Sebastian wrote:
> Hi Sandro,
> I have to pick up the issue with the editConfig again. Attached you
> can find my generated themes.json file. The application states there
> are no editable layers. I have changed nothing else with the editing
> interface etc.
> Do you have any further idea what to look up for? What I have seen is,
> that within the WFS the FeatureTypeName seems to be created by the
> LayerTitle (and so differs from the LayerName in the WMS). Could that
> be an issue?
> Best Regards
> Sebastian Goerke
> Sebastian GOE**RKE*
> Consultant
> *Sopra Steria Consulting***
> Sopra Steria AG
> Barcelona-Allee 1
> 51103 Köln - Deutschland
> Phone: +49 221 92404-8958 - Mobile: +49151 40625945
> sebastian.goerke at soprasteria.com
> <mailto:sebastian.goerke at soprasteria.com> - www.soprasteria.de
> <http://www.soprasteria.de/>
> <https://www.linkedin.com/company/soprasteria><https://www.facebook.com/soprasteria.de><https://twitter.com/SopraSteria_de><https://www.xing.com/company/soprasteria><http://digitale-exzellenz.de/>
> Before printing, think about the environment.
> The content of this message may be confidential, legally privileged
> and protected by law. Unauthorized use, copying or disclosure of any
> of it may be unlawful. If you are not the intended recipient please
> notify the sender and remove it from your system. While attachments to
> this e-mail are checked for viruses, we do not accept any liability
> for any damage sustained by viruses.
> *Von:*Sandro Mani <manisandro at gmail.com>
> *Gesendet:* Donnerstag, 29. März 2018 10:15
> *An:* GOERKE Sebastian <sebastian.goerke at soprasteria.com>;
> qgis-qwc2 at lists.osgeo.org
> *Betreff:* Re: [qgis-qwc2] Question about Editin Plugin
> Hi Sebastian
> There is no out-of-the box implementation for editing, you need to
> implement the EditingInterface [1] to talk to whatever service you
> want to use to handle the editing operations server side.
> As far as the message about no editable layers is concerned, it looks
> like your edit config is not getting picked up. Make sure the
> editConfig is correctly specified in the themesConfig.json and the
> themes.json regenerated. If you run the vanilla qwc2-demo-app you
> should already get a setup where this works, at least to the degree
> that it talks to the dummy EditingInterface.js.
> Hope this helps
> Sandro
> [1]
> https://github.com/qgis/qwc2-demo-app/blob/master/js/EditingInterface.js
> On 29.03.2018 10:07, GOERKE Sebastian wrote:
>     Hi all,
>     I am very happy so say, that QWC2 fits 100 % for our requirements
>     developing a WebGIS for a research project. After successful
>     deployment I will share the link with the list aswell.
>     Currently we are thinking about the Editing Plugin(?)/ Interface.
>     As far as I understood, the built-in implementation uses the QGIS
>     Server WFS. Is that correct? Or do we have to implement something
>     on our own here?
>     What we did was configuring all the things mentioned within the
>     documentation (activation the Plugin, edit themesConfig, adding
>     editConfig) for our specific layer. QWC2 frontend stays saying
>     that there is no layer for editing. Are we missing something here?
>     Best Regards
>     Sebastian
>     **Sebastian GOERKE*
>     Consultant
>     Sopra Steria AG
>     Barcelona-Allee 1
>     privileged and protected by law. Unauthorized use, copying or
>     disclosure of any of it may be unlawful. If you are not the
>     intended recipient please notify the sender and remove it from
>     your system. While attachments to this e-mail are checked for
>     viruses, we do not accept any liability for any damage sustained
>     by viruses.
>     Sopra Steria Consulting is the trading name of:
>     Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent Paris -
>     Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR
>     B 148540 Amtsgericht Hamburg - USt-ID-Nr.: DE118671351
>     _______________________________________________
>     qgis-qwc2 mailing list
>     qgis-qwc2 at lists.osgeo.org <mailto:qgis-qwc2 at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
> Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR B
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20180426/bb64af76/attachment-0001.html>
More information about the qgis-qwc2 mailing list
