[qgis-qwc2] Question about Editin Plugin
Sandro Mani
manisandro at gmail.com
Thu Apr 26 02:19:00 PDT 2018
Hi Sebastian
Does localhost:8081/themes.json match the themes.json you are expecting,
resp. does it contain the editConfig? Did you clear the browser cache?
Best
Sandro
On 26.04.2018 11:14, GOERKE Sebastian wrote:
> Hi Sandro,
> thank you for your fast response.
> I have attached the complete configuration for the web-app and a
> screenshot. Maybe I am missing something here. Thank you very much for
> your help. I am not getting, what goes wrong.
> Best regards
> Sebastian
> **Sebastian GOERKE*
> Consultant
> *Sopra Steria Consulting***
> Sopra Steria AG
> Barcelona-Allee 1
> 51103 Köln - Deutschland
> Phone: +49 221 92404-8958 - Mobile: +49151 40625945
> sebastian.goerke at soprasteria.com
> <mailto:sebastian.goerke at soprasteria.com> - www.soprasteria.de
> <http://www.soprasteria.de/>
> <https://www.linkedin.com/company/soprasteria><https://www.facebook.com/soprasteria.de><https://twitter.com/SopraSteria_de><https://www.xing.com/company/soprasteria><http://digitale-exzellenz.de/>
> Before printing, think about the environment.
> The content of this message may be confidential, legally privileged
> and protected by law. Unauthorized use, copying or disclosure of any
> of it may be unlawful. If you are not the intended recipient please
> notify the sender and remove it from your system. While attachments to
> this e-mail are checked for viruses, we do not accept any liability
> for any damage sustained by viruses.
> *Von:*Sandro Mani <manisandro at gmail.com>
> *Gesendet:* Donnerstag, 26. April 2018 11:02
> *An:* GOERKE Sebastian <sebastian.goerke at soprasteria.com>;
> qgis-qwc2 at lists.osgeo.org
> *Betreff:* Re: AW: [qgis-qwc2] Question about Editin Plugin
> Hi Sebastian
> Your themes.json works here (resp I can see "Natur in der Stadt" as
> editable layer).
> Are you sure the themes.json the client is reading contains the
> editConfig?
> The matching between the layer names in the editConfig and the actual
> WMS names is only important to ensure the WMS layers are correctly
> refreshed after edit changes are committed. The "No editable layers
> found" message really only appears when the editConfig is empty.
> Best
> Sandro
> On 25.04.2018 10:29, GOERKE Sebastian wrote:
> Hi Sandro,
> I have to pick up the issue with the editConfig again. Attached
> you can find my generated themes.json file. The application states
> there are no editable layers. I have changed nothing else with the
> editing interface etc.
> Do you have any further idea what to look up for? What I have seen
> is, that within the WFS the FeatureTypeName seems to be created by
> the LayerTitle (and so differs from the LayerName in the WMS).
> Could that be an issue?
> Best Regards
> Sebastian Goerke
> Sebastian GOE**RKE*
> Consultant
> Sopra Steria AG
> Barcelona-Allee 1
> privileged and protected by law. Unauthorized use, copying or
> disclosure of any of it may be unlawful. If you are not the
> intended recipient please notify the sender and remove it from
> your system. While attachments to this e-mail are checked for
> viruses, we do not accept any liability for any damage sustained
> by viruses.
> <mailto:manisandro at gmail.com>
> *Gesendet:* Donnerstag, 29. März 2018 10:15
> <mailto:sebastian.goerke at soprasteria.com>;
> qgis-qwc2 at lists.osgeo.org <mailto:qgis-qwc2 at lists.osgeo.org>
> *Betreff:* Re: [qgis-qwc2] Question about Editin Plugin
> Hi Sebastian
> There is no out-of-the box implementation for editing, you need to
> implement the EditingInterface [1] to talk to whatever service you
> want to use to handle the editing operations server side.
> As far as the message about no editable layers is concerned, it
> looks like your edit config is not getting picked up. Make sure
> the editConfig is correctly specified in the themesConfig.json and
> the themes.json regenerated. If you run the vanilla qwc2-demo-app
> you should already get a setup where this works, at least to the
> degree that it talks to the dummy EditingInterface.js.
> Hope this helps
> Sandro
> [1]
> https://github.com/qgis/qwc2-demo-app/blob/master/js/EditingInterface.js
> On 29.03.2018 10:07, GOERKE Sebastian wrote:
> Hi all,
> I am very happy so say, that QWC2 fits 100 % for our
> requirements developing a WebGIS for a research project. After
> successful deployment I will share the link with the list aswell.
> Currently we are thinking about the Editing Plugin(?)/ Interface.
> As far as I understood, the built-in implementation uses the
> QGIS Server WFS. Is that correct? Or do we have to implement
> something on our own here?
> What we did was configuring all the things mentioned within
> the documentation (activation the Plugin, edit themesConfig,
> adding editConfig) for our specific layer. QWC2 frontend stays
> saying that there is no layer for editing. Are we missing
> something here?
> Best Regards
> Sebastian
> **Sebastian GOERKE*
> Consultant
> Sopra Steria AG
> Barcelona-Allee 1
> Sopra Steria Consulting is the trading name of:
> Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent
> Paris - Vorstand: Urs Michael Krämer - Sitz der Gesellschaft:
> Hamburg - HR B 148540 Amtsgericht Hamburg - USt-ID-Nr.:
> DE118671351
> qgis-qwc2 mailing list
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
> Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent Paris -
> Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR
> B 148540 Amtsgericht Hamburg - USt-ID-Nr.: DE118671351
> Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR B
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20180426/ab9f10ce/attachment-0001.html>
More information about the qgis-qwc2
