[qgis-qwc2] Question about Editin Plugin
Sandro Mani manisandro at gmail.com
Thu Apr 26 02:58:14 PDT 2018
Hi Sebastian
Yes the default qwc2-demo-app has editing enabled (with the dummy
EditingInterface).
If you zip and send me your entire qwc2-app folder I can have a look.
Best
Sandro
On 26.04.2018 11:51, GOERKE Sebastian wrote:
> Hi Sandro,
> I have attached the output from localhost:8081/themes.json. I used
> Notepad++ to compare the two files and they are equal. I requested the
> app via private mode window, so browser cache should be no issue here.
> As far as I understand, it is only a configuration issue and has
> nothing to do with die editingInterface or other files, right? As the
> documentation does only say “activate editing in appConfig and
> config”, has the default of the qwc2-demo-app editing activated?
> Best regards
> Sebastian
> **Sebastian GOERKE*
> Consultant
> *Sopra Steria Consulting***
> Sopra Steria AG
> Barcelona-Allee 1
> 51103 Köln - Deutschland
> Phone: +49 221 92404-8958 - Mobile: +49151 40625945
> sebastian.goerke at soprasteria.com
> <mailto:sebastian.goerke at soprasteria.com>- www.soprasteria.de
> <http://www.soprasteria.de/>
> cid:image002.png at 01D3DD51.986C7310
> <https://www.linkedin.com/company/soprasteria>cid:image003.png at 01D3DD51.986C7310
> <https://www.facebook.com/soprasteria.de>cid:image004.png at 01D3DD51.986C7310
> <https://twitter.com/SopraSteria_de>cid:image005.png at 01D3DD51.986C7310
> <https://www.xing.com/company/soprasteria>cid:image006.png at 01D3DD51.986C7310
> <http://digitale-exzellenz.de/>
> Before printing, think about the environment.
> The content of this message may be confidential, legally privileged
> and protected by law. Unauthorized use, copying or disclosure of any
> of it may be unlawful. If you are not the intended recipient please
> notify the sender and remove it from your system. While attachments to
> this e-mail are checked for viruses, we do not accept any liability
> for any damage sustained by viruses.
> *Von:*Sandro Mani <manisandro at gmail.com <mailto:manisandro at gmail.com>>
> *Gesendet:* Donnerstag, 26. April 2018 11:19
> *An:* GOERKE Sebastian <sebastian.goerke at soprasteria.com
> <mailto:sebastian.goerke at soprasteria.com>>; qgis-qwc2 at lists.osgeo.org
> <mailto:qgis-qwc2 at lists.osgeo.org>
> *Betreff:* Re: AW: AW: [qgis-qwc2] Question about Editin Plugin
> Hi Sebastian
> Does localhost:8081/themes.json match the themes.json you are
> expecting, resp. does it contain the editConfig? Did you clear the
> browser cache?
> Best
> Sandro
> On 26.04.2018 11:14, GOERKE Sebastian wrote:
>     Hi Sandro,
>     thank you for your fast response.
>     I have attached the complete configuration for the web-app and a
>     screenshot. Maybe I am missing something here. Thank you very much
>     for your help. I am not getting, what goes wrong.
>     Best regards
>     Sebastian
>     **Sebastian GOERKE*
>     Consultant
>     Sopra Steria AG
>     Barcelona-Allee 1
>     privileged and protected by law. Unauthorized use, copying or
>     disclosure of any of it may be unlawful. If you are not the
>     intended recipient please notify the sender and remove it from
>     your system. While attachments to this e-mail are checked for
>     viruses, we do not accept any liability for any damage sustained
>     by viruses.
>     *Von:*Sandro Mani <manisandro at gmail.com> <mailto:manisandro at gmail.com>
>     *Gesendet:* Donnerstag, 26. April 2018 11:02
>     *An:* GOERKE Sebastian <sebastian.goerke at soprasteria.com>
>     <mailto:sebastian.goerke at soprasteria.com>;
>     qgis-qwc2 at lists.osgeo.org <mailto:qgis-qwc2 at lists.osgeo.org>
>     *Betreff:* Re: AW: [qgis-qwc2] Question about Editin Plugin
>     Hi Sebastian
>     Your themes.json works here (resp I can see "Natur in der Stadt"
>     as editable layer).
>     Are you sure the themes.json the client is reading contains the
>     editConfig?
>     The matching between the layer names in the editConfig and the
>     actual WMS names is only important to ensure the WMS layers are
>     correctly refreshed after edit changes are committed. The "No
>     editable layers found" message really only appears when the
>     editConfig is empty.
>     Best
>     Sandro
>     On 25.04.2018 10:29, GOERKE Sebastian wrote:
>         Hi Sandro,
>         I have to pick up the issue with the editConfig again.
>         Attached you can find my generated themes.json file. The
>         application states there are no editable layers. I have
>         changed nothing else with the editing interface etc.
>         Do you have any further idea what to look up for? What I have
>         seen is, that within the WFS the FeatureTypeName seems to be
>         created by the LayerTitle (and so differs from the LayerName
>         in the WMS). Could that be an issue?
>         Best Regards
>         Sebastian Goerke
>         Sebastian GOE**RKE*
>         Consultant
>         Sopra Steria AG
>         Barcelona-Allee 1
>         *Gesendet:* Donnerstag, 29. März 2018 10:15
>         *Betreff:* Re: [qgis-qwc2] Question about Editin Plugin
>         Hi Sebastian
>         There is no out-of-the box implementation for editing, you
>         need to implement the EditingInterface [1] to talk to whatever
>         service you want to use to handle the editing operations
>         server side.
>         As far as the message about no editable layers is concerned,
>         it looks like your edit config is not getting picked up. Make
>         sure the editConfig is correctly specified in the
>         themesConfig.json and the themes.json regenerated. If you run
>         the vanilla qwc2-demo-app you should already get a setup where
>         this works, at least to the degree that it talks to the dummy
>         EditingInterface.js.
>         Hope this helps
>         Sandro
>         [1]
>         https://github.com/qgis/qwc2-demo-app/blob/master/js/EditingInterface.js
>         On 29.03.2018 10:07, GOERKE Sebastian wrote:
>             Hi all,
>             I am very happy so say, that QWC2 fits 100 % for our
>             requirements developing a WebGIS for a research project.
>             After successful deployment I will share the link with the
>             list aswell.
>             Currently we are thinking about the Editing Plugin(?)/
>             Interface.
>             As far as I understood, the built-in implementation uses
>             the QGIS Server WFS. Is that correct? Or do we have to
>             implement something on our own here?
>             What we did was configuring all the things mentioned
>             within the documentation (activation the Plugin, edit
>             themesConfig, adding editConfig) for our specific layer.
>             QWC2 frontend stays saying that there is no layer for
>             editing. Are we missing something here?
>             Best Regards
>             Sebastian
>             **Sebastian GOERKE*
>             Consultant
>             Sopra Steria AG
>             Barcelona-Allee 1
>             www.soprasteria.de <http://www.soprasteria.de/>
>             or disclosure of any of it may be unlawful. If you are not
>             the intended recipient please notify the sender and remove
>             it from your system. While attachments to this e-mail are
>             checked for viruses, we do not accept any liability for
>             Sopra Steria Consulting is the trading name of:
>             Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent
>             Paris - Vorstand: Urs Michael Krämer - Sitz der
>             Gesellschaft: Hamburg - HR B 148540 Amtsgericht Hamburg -
>             USt-ID-Nr.: DE118671351
>             _______________________________________________
>             qgis-qwc2 mailing list
>             https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
>         Paris - Vorstand: Urs Michael Krämer - Sitz der Gesellschaft:
>         Hamburg - HR B 148540 Amtsgericht Hamburg - USt-ID-Nr.:
>         DE118671351
>     Sopra Steria AG - Vorsitzender des Aufsichtsrates: Vincent Paris -
>     Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR
>     B 148540 Amtsgericht Hamburg - USt-ID-Nr.: DE118671351
> Vorstand: Urs Michael Krämer - Sitz der Gesellschaft: Hamburg - HR B
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20180426/d50a6484/attachment-0001.html>
More information about the qgis-qwc2 mailing list
