[qgis-qwc2] Reporting
Sandro Mani manisandro at gmail.com
Fri Apr 19 13:59:53 PDT 2019
Hi Bernhard
You might want to set add a console.log(reports) here [1] for debugging
to see whether the reports were correctly collected from the themes
configuration, and perhaps also a console.log(layer) to see which layer
name is actually used.
Best
Sandro
[1]
https://github.com/qgis/qwc2/blob/master/components/IdentifyViewer.jsx#L458
On 18.04.19 13:10, Bernhard Ströbl wrote:
> Hi Sandro,
> thanks for this information (maybe you want to update
> themesConfig.json accordingly). Unfortunately I do not get such a link
> in the feature-info result dialog. I used both, name and title of the
> layer...
> reagards
> Bernhard
> Am 18.04.2019 um 11:33 schrieb Sandro Mani:
>> Hi Bernhard
>> The dictionary in the themesConfig.json ist just a mapping
>> <layername>: <reportname>
>> So, in the feature info result dialog, if a report is configured for
>> the respective layer via the above mapping, a link will appear which
>> will point to
>> <serviceUrl>/<template>?feature=<featureId>&x=<mouseX>&y=<mouseY>&crs=<crs>
>> Best
>> Sandro
>> On 18.04.19 07:45, Bernhard Ströbl wrote:
>>> Hi Sandro,
>>> thanks for pointing me to the repo. My basic idea was to run Jasper
>>> via QGIS Server plugin (I have that already) but I will look at your
>>> reporting-service project, too.
>>> However: how (where) can I call the report from qwc2-demo-app?
>>> And further: in the sample themesConfig.json it says: "a":
>>> "template_a" - what is "a" referring to?
>>> all the best
>>> Bernhard
>>> Am 17.04.2019 um 16:46 schrieb Sandro Mani:
>>>> Hi Bernhard
>>>> You will need an actual reporting service which returns a document
>>>> when invoked as
>>>> where template is what you configured in themesConfig.json.
>>>> The reporting service could be a jasper reporting service like [1],
>>>> or something else.
>>>> Best
>>>> Sandro
>>>> [1] https://github.com/qwc-services/jasper-reporting-service
>>>> On 17.04.19 12:45, Bernhard Ströbl wrote:
>>>>> Hi,
>>>>> could anybody explain how to configure and run reports? Anybody
>>>>> has a working example?
>>>>> Following the documentation I added an URL for
>>>>> featureReportService in config.json and used "featureReport":{...
>>>>> as given in the sample themesConfig.json.
>>>>> How/where can I access the report now? Or do I have to implement
>>>>> something e.g. in the getFeatureInfo being returned from the
>>>>> WMS-Server?
>>>>> How can I associate a report to a certain layer?
>>>>> regards
>>>>> Bernhard
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 19214 (20190418) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>>> qgis-qwc2 mailing list
>>> qgis-qwc2 at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
> signature database 19215 (20190418) __________
> http://www.eset.com
More information about the qgis-qwc2 mailing list
