[qgis-qwc2] map tips
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Feb 14 02:49:06 PST 2019
Am 14.02.2019 um 11:47 schrieb Sandro Mani:
> Hi Bernhard
> Have you changed both the mobile and desktop configurations in
> config.json (resp. the one that you are testing?)
Yep, maybe it is a caching problem, will try again later and call back
Bernhard
> Sandro
> On 14.02.19 11:46, Bernhard Ströbl wrote:
>> Am 14.02.2019 um 11:27 schrieb Sandro Mani:
>>> Hi Bernhard
>>> If you look in the network inspector, do you see you change reflected
>>> in the GetFeatureInfo request URL?
>> no, the GetFeatureInfo request is sent with "with_maptip=true"
>>> feature_count simply limits the number of features QGIS Server returns.
>> I would have guessed :-)
>> Bernhard
>>> Sandro
>>> On 14.02.19 11:26, Bernhard Ströbl wrote:
>>>> Hi Sandro,
>>>> doesn't work here. Is a certain Version of QGIS Server and/or qwc2
>>>> required?
>>>> BTW what is "feature_count" good for?
>>>> Bernhard
>>>> Am 14.02.2019 um 11:15 schrieb Sandro Mani:
>>>>> Hi
>>>>> This is already possible, just set:
>>>>> with_maptip: false
>>>>> in the Identify cf params in config.json, i.e.
>>>>> "name": "Identify",
>>>>> "cfg": {
>>>>> "params": {
>>>>> "FI_POINT_TOLERANCE": 32,
>>>>> "FI_LINE_TOLERANCE": 16,
>>>>> "FI_POLYGON_TOLERANCE": 8,
>>>>> "feature_count": 20,
>>>>> "with_maptip": false
>>>>> Best
>>>>> Sandro
>>>>> On 14.02.19 08:17, Andreas Neumann wrote:
>>>>>> Hi,
>>>>>> Now that we can do GetFeatureInfo WITH_MAPTIP true|false, QWC2
>>>>>> could use with maptip for mouseover and without maptip for click.
>>>>>> This should be relatively easy to implement - right?
>>>>>> Greetings,
>>>>>> Andreas
>>>>>> On 2019-02-14 08:06, Bernhard Ströbl wrote:
>>>>>>> Hi Sandro,
>>>>>>> it works with maptip (used to be tooltip in QWC1).
>>>>>>> Unfortunately when clicking on a feature the field maptip is
>>>>>>> included in the feature info, too, which IMHO is kinda ungly.
>>>>>>> Bernhard
>>>>>>> Am 07.02.2019 um 23:44 schrieb Sandro Mani:
>>>>>>>> Hi Bernhard
>>>>>>>> Does your GetFeatureInfo reply include a feature with an
>>>>>>>> attribute named "maptip"?
>>>>>>>> Best
>>>>>>>> Sandro
>>>>>>>> On 07.02.19 17:38, Bernhard Ströbl wrote:
>>>>>>>>> Hi all,
>>>>>>>>> I am trying to understand the map tips in QWC2. When enabling
>>>>>>>>> them I see GetFeatureInfo requests being sent while moving the
>>>>>>>>> mouse cursor. These very GetFeatureInfo requests being entered
>>>>>>>>> in a new browser tab return an answer with feature info but in
>>>>>>>>> qwc2-demo-app nothing happens. I would expect a popup or similar.
>>>>>>>>> Is there anything I have overlooked to configure in my QGIS
>>>>>>>>> Server project or in my qwc2 client?
>>>>>>>>> any help appreciated
>>>>>>>>> Bernhard
>>>>>>>>> __________ Information from ESET Mail Security, version of
>>>>>>>>> virus signature database 18837 (20190207) __________
>>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>>> http://www.eset.com
>>>>>>>>> _______________________________________________
>>>>>>>>> qgis-qwc2 mailing list
>>>>>>>>> qgis-qwc2 at lists.osgeo.org <mailto:qgis-qwc2 at lists.osgeo.org>
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
__________ Information from ESET Mail Security, version of virus signature database 18873 (20190214) __________
http://www.eset.com
More information about the qgis-qwc2
