[qgis-qwc2] Issue publishing Arctic project in EPSG:3996 with QWC2 (CRS not defined & anti-meridian splitting)
Sandro Mani
manisandro at gmail.com
Tue Dec 23 23:56:22 PST 2025
Hi
You can register custom projections in the config.json -> projections block.
Hope this helps
Sandro
On 24.12.25 04:39, 김용운 빙하지권연구본부 via qgis-qwc2 wrote:
> Hello,
> I am working on publishing a QGIS project to QWC2 in order to share
> Arctic Ocean datasets in a web environment.
> Because my datasets are located in the Arctic, I normally use
> EPSG:3996 (WGS 84 / Polar Stereographic) as the project CRS in QGIS.
> In desktop QGIS, this CRS works correctly and produces the expected
> visualization (Figure 1).
> However, when publishing the project to QWC2, the theme fails to load
> and QWC2 reports that “the projection EPSG:3996 is not defined”
> (Figure 2). Due to this limitation, I changed the project CRS to
> EPSG:3857 so that the project can be loaded in QWC2.
> With this workaround, I encounter serious rendering issues for
> datasets crossing the 180° meridian (anti-meridian):
> - line and track features are split and rendered at both edges of the map,
> - and in some CRS combinations the geometries appear heavily distorted
> (Figures 3 and 5).
> For reference, these are the main configurations I tested:
> - Desired QGIS desktop view:
> Project CRS = EPSG:3996, Layer CRS = EPSG:4326 (Figure 1)
> - QWC2 workaround configuration:
> Project CRS = EPSG:3857, Layer CRS = EPSG:3996 (Figure 3)
> I tried multiple CRS combinations, but this setup provided the closest
> overall alignment in QWC2, although the anti-meridian splitting
> problem remains. I also tested several approaches suggested in
> documentation and online resources (e.g. tile-based basemaps, geometry
> correction), but none resolved the underlying issue.
> Since many of my Arctic datasets cross the 180° meridian, this problem
> affects a large portion of the data and prevents producing a visually
> continuous map.
> Could you please advise on:
> - whether EPSG:3996 can be properly supported in QWC2, or
> - the recommended workflow for publishing Arctic (polar) data in QWC2
> without visual discontinuities at the anti-meridian?
> Any guidance regarding CRS configuration, QGIS Server / QWC2 settings,
> or preprocessing strategies would be greatly appreciated.
> Thank you very much for your help.
> Best regards,
> qgis-qwc2 mailing list
> qgis-qwc2 at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
URL: <http://lists.osgeo.org/pipermail/qgis-qwc2/attachments/20251224/42c48d5a/attachment.htm>
More information about the qgis-qwc2
