[qgis-qwc2] Redirect to login page for unauthenticated users
Benjamin Cahill
bcahill at alertacademy.com
Mon Jul 6 13:01:33 PDT 2026
Hello,
I found the following messages in my Drafts folder from last year. I'm
not sure if it is the whole story, but if nothing else, it may be
helpful information to someone else.
We are using QField more than QWC2 at this point, but QWC2 does seem
to be working better than it was as far as the login aspect.
I figured out how to redirect users that are not logged in to the login page.
In the file qwc-services/config-in/default/config.json, set the
Authentication plugin's requireLogin parameter to true as follows:
"name":"Authentication",
"cfg":{
"requireLogin":true
Note that this needs to be done twice in the file—once in the mobile
section and once in the desktop section.
This looks like it is working as intended now and redirecting
logged-out users to the login page.
- Benjamin
On Mon, May 5, 2025 at 10:39 AM Benjamin Cahill
<bcahill at alertacademy.com> wrote:
> Sandro,
> Yes, this is at the top of the generated file
> config/default/mapViewerConfig.json :
> "$schema": "https://github.com/qwc-services/qwc-map-viewer/raw/2024-lts/schemas/qwc-map-viewer.json",
> "service": "map-viewer",
> "config": {
> "qwc2_path": "/qwc2/",
> "auth_service_url": "/ldap/",
> "data_service_url": "/api/v1/data/",
> "#document_service_url": "/api/v1/document/",
> "elevation_service_url": "/elevation/",
> "info_service_url": "/api/v1/featureinfo/",
> "legend_service_url": "/api/v1/legend/",
> "mapinfo_service_url": "/api/v1/mapinfo/",
> "ogc_service_url": "/ows/",
> "permalink_service_url": "/api/v1/permalink/",
> "#print_service_url": "/api/v1/print/",
> "search_service_url": "/api/v2/search/",
> "search_data_service_url": "/api/v2/search/geom/",
> "auth_required": true
> - Benjamin
> On Sat, May 3, 2025 at 9:13 AM Sandro Mani <manisandro at gmail.com> wrote:
> > Hello
> > Do you see auth_required: true in the generated mapViewerConfig.json?
> > Sandro
> > On 01.05.25 17:48, Benjamin Cahill via qgis-qwc2 wrote:
> > > Hello,
> > > Is there a way to redirect users that are not logged in to the login page?
> > > I found the "auth_required" option documented on the following page:
> > > https://qwc-services.github.io/master/references/qwc-map-viewer/
> > > But even after adding it to tenantConfig.json and re-generating the
> > > config, it still does not redirect a new unauthenticated user (fresh
> > > incognito window) to the login page.
> > > "name": "mapViewer",
> > > "generator_config": {
> > > "qwc2_config": {
> > > "qwc2_config_file": "/srv/qwc_service/config-in/default/config.json",
> > > "qwc2_index_file": "/srv/qwc_service/config-in/default/index.html"
> > > "config": {
> > > I did try forcing a redirect from my webserver config by checking for
> > > an access_token_cookie cookie, but that introduced other problems.
> > > Does anyone know how to get the auth_required option to redirect
> > > unauthenticated users to the login page?
> > > Thank you,
> > > - Benjamin
> > > _______________________________________________
> > > qgis-qwc2 mailing list
> > > qgis-qwc2 at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/qgis-qwc2
More information about the qgis-qwc2
