[Qgis-tr] tip text changes
Werner Macho
werner.macho at gmail.com
Thu Jul 4 06:28:19 PDT 2013
Thanks for showing that Richard ..
It should be fixed now ..
Maybe we gotta create a task list which we should follow to take a
look if everything is up to date before a release..
I've seen that a lot of the help files under ressources are out of
date or not showing the actual state of whats going on in the function
but anyway .. thanks for this Richard
regards
Werner
On Wed, Jul 3, 2013 at 6:03 PM, Richard Duivenvoorde <richard at duif.net> wrote:
> During translation I found some 'tips' which are not ok anymore because of
> gui changes (I think):
> In this one:
> In the print composer tool bar you can find two buttons for moving elements.
> The left one (right arrow icon) selects and moves elements in the layout.
> After selecting the element with this tool you can also move them around
> with the arrow keys. For accurate positioning use the <strong>Position and
> Size</strong> dialogue, which can be found in the tab <strong>Item
> Properties -> General Options -> Position and Size</strong>. The other move
> tool (map canvas icon with right arrow) allows one to move the map content
> within a map frame.
> The positioning stuff is not in
> Item Properties -> General Options -> Position and Size
> but just in
> Item Properties -> -> Position and Size
> and besides that, it is not a dialog anymore (in other tips we call it
> 'sections' now)
> In this one:
> Sometimes you have a very large dataset which takes ages to draw. You can
> press 'Esc' (the escape key), or click the small red 'X' icon in the status
> bar to the bottom right of the window at any time to halt rendering. If you
> are going to be performing several actions (e.g. modifying symbology
> options) and wish to temporarily disable map rendering while you do so, you
> can uncheck the 'Render' checkbox in the bottom right of the status bar.
> Don't forget to check it on again when you are ready to have the map draw
> itself again!
> There is no 'small red X icon' anymore. I call it the 'Stop map
> rendering'-button myself in the translation.
> Last one:
> You can rotate a map by setting its rotation value in the <strong>Item
> Properties -> Map</strong> section. To place a north arrow in your layout
> you can use the <strong>Add Image</strong> tool. After the selection and
> placement of the north arrow in the layout you can link it with a specific
> map frame by activating the <strong>Sync with map</strong> checkbox and
> selecting a map frame. Whenever you change the rotation value of a linked
> map, the north arrow will now automatically adjust its rotation.
> Item Properties -> Map
> should be
> Item Properties -> Map -> Main properties
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr
