[Qgis-tr] Follow up to the String Freeze!
Xan Vieiro gallaecia6 at gmail.com
Fri Jul 12 05:14:13 PDT 2013
Typos report:
In function_help context, in the 'clamp() function' there is an example :
 clamp(1,11,10) → 10 (<i>input</i> is greater than maximum value of
10, so function returns 11)<br>
It must be 10, isn't it??
2013/7/12 Jürgen E. <jef at norbit.de>
> Hi Artem,
> On Fri, 12. Jul 2013 at 15:52:19 +0700, Artem Popov wrote:
> > 1. Broken string formatting in
> > src/providers/oracle/qgsoracleprovider.cpp. Note the 2nd %2 argument,
> > should be %3:
> > 2234:QgsMessageLog::logMessage( tr( "Could not update metadata for
> > %1.%2.\nSQL:%1\nError: %2" )
> fixed.
> > 4. mismatched square brackets in src/core/qgsfeature.cpp:
> > 195:Attribute index %1 out of bounds [0;%2[
> That's correct. That means that the range doesn't include the upper bound.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20130712/e981c1ee/attachment.html>
More information about the Qgis-tr mailing list
