[Qgis-tr] Follow up to the String Freeze!
Werner Macho
werner.macho at gmail.com
Thu Jul 18 04:15:34 PDT 2013
Hi!
Thanks for reporting!
The first one (if you mean the %s[ ) is actually correct like it is
and the second one is already fixed in master .. thanks
Shall I update your .ts file or do you want to do that by yourself?
kind regards
Werner
On Thu, Jul 18, 2013 at 1:13 PM, QGIS Brasil Comunidade brasileira
<qgisbrasil at gmail.com> wrote:
> More two typos at strings:
> Attribute index %1 out of bounds [0;%2[
> %1 of %2 bad layers were not not fixable.
> 2013/7/18 Werner Macho <werner.macho at gmail.com>
>> Thanks Artem.
>> however you like .. you can even do some pill requests in between ..
>> thanks
>> Werner
>> On Thu, Jul 18, 2013 at 9:28 AM, Artem Popov <artfwo at gmail.com> wrote:
>> > Very well, but I still stumble upon typos here and there. I can
>> > consolidate them all in a single pull request just a bit later.
>> > 2013/7/18 Paolo Cavallini <cavallini at faunalia.it>:
>> >> -----BEGIN PGP SIGNED MESSAGE-----
>> >> Hash: SHA1
>> >> Il 18/07/2013 05:51, Artem Popov ha scritto:
>> >>> More typos in the topology plugin:
>> >> Hi Artem,
>> >> thanks for this. Could you please add a ticket on this, or even better
>> >> provide a pull
>> >> request or a patch?
>> >> All the best.
>> >> Paolo Cavallini - Faunalia
>> >> www.faunalia.eu
>> >> Full contact details at www.faunalia.eu/pc
>> >> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> >> -----BEGIN PGP SIGNATURE-----
>> >> Version: GnuPG v1.4.12 (GNU/Linux)
>> >> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> >> iEYEARECAAYFAlHnhQQACgkQ/NedwLUzIr7Q+ACfR5LjV4ReQSFqhhNv6JTTFSXP
>> >> LZ0An338kyCHH6wEYpxjqpSc75nVX66X
>> >> =fYXk
>> >> -----END PGP SIGNATURE-----
>> >> _______________________________________________
>> >> Qgis-tr mailing list
>> >> Qgis-tr at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-tr
> Comunidade QGISBrasil
> www.qgisbrasil.org
> comunidade at qgisbrasil.org
More information about the Qgis-tr
