[Qgis-tr] linguist vs. transifex in GUI translation
Carlos Dávila cdavilam at orangecorreo.es
Wed Apr 16 13:24:46 PDT 2014
As the only translator of Spanish, I will continue with Qt Linguist
El 16/04/14 10:04, Werner Macho escribió:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Dear Translators!
> During the last Codesprint I took the time for a few Discussions with
> developers and users and took a look on transifex.
> I decided to make a TEST PHASE for transifex:
> Short conclusion:
> You can EITHER use transifex OR linguist with the direct qgis_*.ts file.
> There is currently no fast/reasonable way to merge them both.
> Longer story:
> The current way of translations is to checkout the source from github
> (or download only the qgis_**.ts file of your language and translate
> it with linguist.
> With Linguist this has a few benefits:
> * If you checked out the source and probably compiled QGIS on your own
> you will see the "environment" of the string you are currently
> translating and will have a better feeling if the strings will fit or not.
> * You can easily work offline
> Transifex:
> * Is easier to handle for beginners
> * Is Web based with the possibility to download the file (but that
> will lock it for other users)
> We tried a lot of things to combine these two possibilities but the
> merge was always problematic.
> So I am going to leave it to the language coordinators (of a team) or
> if there is only one person translating to the translator if he wants
> to choose either linguist and the qgis_**.ts file _OR_ webbased transifex.
> Remember there is only ONE source that can be included into QGIS.
> For all language-coordinators I only want to know which way you choose
> so that I can make a list which translation is coming from which
> source before a release.
> (direct translation in linguist means less work for me :) - with
> transifex I will download the "finished" file and integrate it into
> QGIS Source.
> I will "clean" the transifex page soon to only include the languages
> that decided to translate with transifex.
> So lets test if we can integrate transifex this way.
> Please bear in mind that whenever you choose one translation type the
> OTHER one will be overruled by your decision.
> If you decide to use transifex I can update the language to the very
> latest state from github.
> I need some volunteers to test! :)
> Let's hope it will work the way we want it.
> thanks a lot for all your effort in translation!
> kind regards
> Werner
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iEYEARECAAYFAlNOOXUACgkQDAH1YiCxBglw8wCdGhN3nSl4QmGVa9WQT/YBPk9A
> fF8An2t0UhBdf55BNsVKNSjyiFaoxL/a
> =r+Qq
> -----END PGP SIGNATURE-----
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
Por favor, no me envíe documentos con extensiones .doc, .docx, .xls, .xlsx, .ppt, .pptx, .mdb, mdbx
Instale LibreOffice desde http://es.libreoffice.org/descarga/
LibreOffice es libre: se puede copiar, modificar y redistribuir libremente. Gratis y totalmente legal.
LibreOffice está en continuo desarrollo y no tendrá que pagar por las nuevas versiones.
More information about the Qgis-tr mailing list
