[Qgis-tr] QGIS Translators (qgis-tr at lists.osgeo.org)
Werner Macho werner.macho at gmail.com
Mon Apr 28 08:27:44 PDT 2014
Hi Alexandre!
They recently changed a lot on transifex and I have to reorientate
myself too but currently I cannot find any lock there too..
Maybe they found a way to merge the files? Or they just forgot ..
But I think downloading and uploading again should not be that problem
.. With a small team changes in the meantime should be less.
If I can find a way to lock the file I will post it here ..
kind regards
Werner
On Mon, Apr 28, 2014 at 4:16 PM, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello werner,
> I have updated the spreadsheet with PT-pt.
> One question, will it be possible to lock a specific language translation
> for a couple of hours in order to download the ts file and perform some
> cleanups? (For example to find and replace a word)
> I know this was possible before, but I can't seem to find it.
> Best regards,
> Alexandre Neto
> On Mon, Apr 28, 2014 at 3:06 PM, Jean-Roc Morreale <jr.morreale at enoreth.net>
> wrote:
>> Hi Werner,
>> Could you set the script to do a daily update if there has been
>> modifications made ? This would be a similar behaviour than with github and
>> would keep qgis-dev build in sync.
>> Is there a way to have a real log in transifex ? For now, I've just find
>> how to see who/when but not what exact string has been changed
>> Qgis-tr mailing list
>> Qgis-tr at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr mailing list
