[Qgis-tr] [Qgis-developer] size of translations, use a distinct repo?
Richard Duivenvoorde
richard at duif.net
Wed Nov 12 01:06:22 PST 2014
Hi Werner,
I think Jürgen is right, we do not need to PULL the qgis_en.ts from
transifex anymore.
The only function of that ts file is:
-1- to use as a template (pot?) for all other language during updating
of other ts files
BUT we actually do not need to pull back this anymore, as for building
(languages) we PULL the non-english ones from transifex. This (pulling)
could indeed be a compile step if you want, though it needs you to have
the tx-cli tools in place for this.
-2- to be the 'source' for transifex.
So we only need to PUSH the english version to transifex (when the
source strings have been changed).
Plz correct me if I'm wrong.
regards,
Richard
On 12-11-14 09:41, Werner Macho wrote:
> Hi Jürgen!
> I am not sure what are you aiming at, but yes - we could do it that way too.
> As long as QGIS does not use qgis_en.ts we could just tx pull it -
> update it and tx push it back to transifex.
> (And forget about it in the source tree). The same way we could do it
> with all the translations.. pulling the right in front of a compile
> run and forget about them afterwards and only commit them right in
> front of a branching the release branch.
> As I said - as long as translations can be considered to be in the
> nightly build I am confident that people compiling QGIS on their own
> can also pull translations before they build.
> The only problem I see is when nightly is not updating translations
> and people cannot see their translations (and possibly adjust it).
> (This only because I sometimes got asked about updating the languages
> in the source tree so that translators can see the work before it is
> getting "released")
> If I am getting you correct we could update the i18n directory only
> once per release. Is this what you are aiming for?
> kind regards
> Werner
> On Wed, Nov 12, 2014 at 9:31 AM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Werner,
>> On Tue, 11. Nov 2014 at 23:24:07 +0100, Werner Macho wrote:
>>> Sounds like a reasonable idea to me, if the translations will be in
>>> nightly I've got no problem (and I also think that the translators
>>> don't have any). For people compiling out of sources it shouldn't be
>>> any problem to pull from transifex either and compile.
>> If I update qgis_en.ts the usual way, there are now differences (e.g. '
>> instead of '). Looks like qgis_en.ts was pulled from transifex. Is that
>> necessary for anything? And how does transifex handle changes like that?
>> On second thought do we need a uptodate qgis_en.ts in our repository at all?
>> QGIS doesn't use it - it's only there for transifex to watch.
>> Instead of updating and commiting it in the source repository (and see lots of
>> otherwise useless changes) we could simply have update_ts_files.sh pull it from
>> transifex, update it with the latest source changes and push it back.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden http://www.norbit.de
>> QGIS release manager (PSC) Germany IRC: jef on FreeNode
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.9 (GNU/Linux)
>> iQIVAwUBVGMa+xBsJ9SQbsVUAQIbwRAAtuxd3KfMQtBWDm7kYg478kWW9baN4bEe
>> oTTAst0RzohGrQy9ePN8NQdiWxOzEJih0VnSYoFr9F+6A5eZ2S6IrC6vUUpX0fh6
>> 6oTqc0Cxf5GyzGhtMQA1uzLXCjXRLJkEGrylTpC1MvhVzsiRxSj7hCJdEEAzJOKt
>> rybxf9Gtb7QSxAT2DNedmYPhfPpRzvcTB/JruDSjExHFxH7cH11iQpnhPv06+YVG
>> 1MTQXIRuNQnMYhPj4MXqSbTzOhH/YcDfgf62k2RnKWhszzcLWIXBVz/m9Wl1gKXJ
>> J0uNQYX9DKH1PbxR/HQ+GYxdX5/4NPEaM2T/mOGewWgVH0x79FX/3jFzvIhMrXJd
>> 7yFFkWBlHpf8Ish0XoTaf5NbiH8Kha1DZsiXFwqh0tZOazuxRdoQC+WZ9Kg/0ESQ
>> /jZe/eWP7/k7Kh9t2QOnJ7iqoqaK8hEdwHjC6MUece4CO8fmj+1SIS+xcb56ILK8
>> dmP07G43mkWcnD7Dc25x6/bDB+hjCtMqkbDrBUtmpR4SJMHfJ7crIiQbiuslrHPe
>> 56MFXud5dY8ykjY0Z0ELZ2XFPaenMLbAu0sUd1DbLi8vyeo8kY4oOeleuFp50Y+x
>> hHy45bkc1hRlVNrHSHmZjhBJQ+sp0X/N4S7r6RlxkXsWkqx5Kly76lzMM4TVoDBk
>> Tk8OTIGhSwk=
>> =YvwM
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr
