[Qgis-tr] Transifex: pros and cons
Werner Macho
werner.macho at gmail.com
Mon Mar 23 02:02:27 PDT 2015
Hi all!
I'm going to do some tests about the best way howto deal with that.
IIRC you can download the ts file - rename it - copy it to the place
in the source tree - translate it - rename it back to what it was
while downloading and upload it again.
(though not tested yet)
regards
Werner
On Mon, Mar 23, 2015 at 9:59 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il 23/03/2015 09:24, Richard Duivenvoorde ha scritto:
>> I think I've seen (relative) path's to the ui-files in earlier .ts files.
>> Not sure if these are still available after a upload/download to
>> Transifex....
>> But apparently Linguist is able to build/show the dialog based on the ui
>> file (IF it can find the ui file).
>> One way to get this off course is to run the (old?) tsscripts yourself?
> Thanks for the suggestion: can we have a simple howto for all, or can we
> provide the previewable version at some stage, for all languages?
> I think this will help a lot.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
More information about the Qgis-tr
