[Qgis-tr] Transifex: pros and cons
Richard Duivenvoorde richard at duif.net
Mon Mar 23 10:16:01 PDT 2015
On 23-03-15 17:58, Paolo Cavallini wrote:
> Il 23/03/2015 17:32, Jürgen E. Fischer ha scritto:
>> Hi Paolo,
>> On Mon, 23. Mar 2015 at 16:47:17 +0100, Paolo Cavallini wrote:
>>> Please let us know when we can download the ts from TX, and see the
>>> previews in linguist, so we will start fixing it.
>> It was already done, when I did my previous reply.
> confirmed, it works.
> for the rest of us:
> * dowload your .ts from
> https://www.transifex.com/projects/p/QGIS/resource/qgis-application/l/$lang/download/for_use/
> (replace $lang with your language: it etc.)
> * save it under QGIS/i18n/qgis_$lang.ts
> * open with linguist, and fix translations.
> I'm unsure how to upload it back to tx.
> All the best, and thanks again.
I think your link will only work for coordinators.
Be carefull, only the coordinator should do this as you are overwriting
translations which are done in the meantime by others....
I'm not using your link, but the dialog you get here:
  https://www.transifex.com/projects/p/QGIS/language/<YOURLANG>/
and then click on 'qgis-application '
in that dialog you (I think in coordinator role) can also upload a tx
file...
Regards,
Richard
More information about the Qgis-tr mailing list
