[Qgis-tr] Translation bugtracker?
    Werner Macho
    werner.macho at gmail.com
    Tue Mar 24 04:15:54 PDT 2015
To discuss such general questions I would suggest to use the qgis-tr
mailinglist.
Maybe other languages could benefit from the suggestions too.
And yes - I think the TX system is going the way of guiding you to
just DO the work if something is wrong and not pointing out things and
delegate them to others ;)
regards
Werner
On Tue, Mar 24, 2015 at 11:36 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Hi Werner,
> Il 24/03/2015 10:17, Werner Macho ha scritto:
>> So it is working as we are used to it from github. It's just a matter
>> of working with transifex the "correct" way.
> thanks for your comments. I understand your point; my issue was slightly
> different. In case I want to point out an issue on a single string, the
> TX system is fine. If I want to open a more general question (e.g.
> "Replace all first person tense of verbs with third"), should I attach
> this to one particular string? This does not sound right to me.
> In addition, finding the right string to open an issue is already half
> of the work ;)
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
More information about the Qgis-tr
