[Qgis-tr] some questions
Richard Duivenvoorde rdmailings at duif.net
Sun Oct 1 02:01:53 PDT 2017
On 01-10-17 00:33, Jürgen E. Fischer wrote:
>> 3) Is there any chance of using the .ts file that you can download from
>> transifex in qgis and see "live" the results of our translation? transifex
>> is very powerful but sometimes is very difficult to translate withow the
>> knowledge of context.
> The nightlies of master pull them in on every build.  But you can also download
> the .ts file for use or translation.
If I am correct, you should be able to:
- download the .ts file from Transifex.com
- use Qt-Linguist to do further translations
- use command line OR Qt-Linguist to 'compile/release' your .ts file to
a .qm file
- if you put THAT .qm file on the right place in your QGIS installation,
QGIS will show you your fresh translations
- do not forget to copy your translations back to transifex, uploading
is also an option, but you will override any translations done while you
downloaded your sources.
HTH
Regards,
More information about the Qgis-tr mailing list
