[Qgis-tr] Question about translation into esperanto
Werner Macho werner.macho at gmail.com
Mon Oct 30 08:03:03 PDT 2017
Hi Axel,
Thanks for helping with the translation.
You should see the maintainer of the language in transifex once you are
accepted to the language.
About github: The files are applied from transifex within every release so
you may probably not see the current language files in github because
translation happens on transifex.
btw: translation on transifex only happens for the "master" so if you are
searching in any already released version you won't find it either.
As you already found your way to the mailing list - just keep asking
whenever a problem arises.
regards
Werner
On Mon, Oct 30, 2017 at 3:46 PM, Axel Rousseau <axel584 at gmail.com> wrote:
> Transifex Webtranslation page for QGIS is on https://www.transifex.com/
> qgis/
> Hi,
> I would like to help to translate QGis to esperanto. I create an account
> on transiflex and ask to join the esperanto team.
> I would like to know who is the maintener of the esperanto version ? and
> how can I contact him to introduce myself ?
> I see that the esperanto version is complete to 45% (on the transiflex
> website) but I don't see the esperanto files on the github repository. Do
> you know why ?
> Thank you for your help,
> Regards,
> Axel Rousseau
> QGIS-Translators mailing list
> Qgis-tr at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20171030/f2f13d00/attachment.html>
More information about the Qgis-tr mailing list
