[Qgis-tr] Available resources
Werner Macho
werner.macho at gmail.com
Thu Apr 23 07:17:52 PDT 2020
Hi!
As long as (in the longer term) QGIS will get no release update for that
versions it makes no sense to unlock them.
We might as well get rid of them, but I assume (still not sure though) that
we'll loose the suggestions for new translations if we remove them.
Are the translations in any way blocking the continuous translation of
master or current LTR release?
regards
Werner
On Thu, Apr 23, 2020 at 4:01 PM Leônidas Descovi Filho <leonprs at gmail.com>
wrote:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi Richard
> Is the goal of the teams to zero the translations?
> If so, in my opinion it either opens up to translate them or withdraws.
> It does not make sense to just be them as pending there in the transifex.
> Regards
> Leônidas
> Em qui., 23 de abr. de 2020 às 10:49, Richard Duivenvoorde <
> rdmailings at duif.net> escreveu:
>> Hi Leônidas,
>> Sorry for my ignorance, but would you still translate 3.4 or 3.8? As
>> these are older non-LTR versions.
>> Is it a problem they are 'locked'?
>> Regards,
>> > Hi
>> > I have a similar problem in the qgis desktop pt_Br.
>> > I request unlocking or removing release-3-4 - qgis-application and
>> > release-3-8 - qgis-application.
>> > Thank you.
>> > Best Regards.
>> > Leônidas
>> > Em qua., 22 de abr. de 2020 às 19:58, Stefano Campus <skampus at gmail.com
>> > <mailto:skampus at gmail.com>> escreveu:
>> > ciao,
>> > sorry if I re-propose the theme.
>> > is it possible to remove from transifex the set of strings to be
>> > translated from the old versions of qgis?
>> > We have Resource that are not editable from:
>> > thank you in advance for your reply
>> > s.
>> > _______________________________________________
>> > QGIS-Translators mailing list
>> > Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>> > https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20200423/85971673/attachment.html>
More information about the Qgis-tr
