[Qgis-tr] Available resources
Stefano Campus
skampus at gmail.com
Thu Apr 23 10:24:10 PDT 2020
ciao,
I agree that having available the strings of versions 3.4 and 3.8 could be
useful, but making massive corrections or validation is then interrupted by
the warning that says that those strings are blocked both for saving and
for validation.
if this involves manual and expensive work I would say that it is not a
problem and that we can easily bear it.
s.
Il giorno gio 23 apr 2020 alle ore 16:28 Leônidas Descovi Filho <
leonprs at gmail.com> ha scritto:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> It is not blocking. The current version can be finalized.
> These are unfinished tasks that will not allow teams to complete 100% of
> qgis desktop translations on the transifex.
> Rgs
> Leônidas
> Em qui., 23 de abr. de 2020 às 11:18, Werner Macho <werner.macho at gmail.com>
> escreveu:
>> Hi!
>> As long as (in the longer term) QGIS will get no release update for that
>> versions it makes no sense to unlock them.
>> We might as well get rid of them, but I assume (still not sure though)
>> that we'll loose the suggestions for new translations if we remove them.
>> Are the translations in any way blocking the continuous translation of
>> master or current LTR release?
>> regards
>> Werner
>> On Thu, Apr 23, 2020 at 4:01 PM Leônidas Descovi Filho <leonprs at gmail.com>
>>> Hi Richard
>>> Is the goal of the teams to zero the translations?
>>> If so, in my opinion it either opens up to translate them or withdraws.
>>> It does not make sense to just be them as pending there in the transifex.
>>> Regards
>>> Leônidas
>>> Em qui., 23 de abr. de 2020 às 10:49, Richard Duivenvoorde <
>>> rdmailings at duif.net> escreveu:
>>>> Hi Leônidas,
>>>> Sorry for my ignorance, but would you still translate 3.4 or 3.8? As
>>>> these are older non-LTR versions.
>>>> Is it a problem they are 'locked'?
>>>> Regards,
>>>> > Hi
>>>> > I have a similar problem in the qgis desktop pt_Br.
>>>> > I request unlocking or removing release-3-4 - qgis-application and
>>>> > release-3-8 - qgis-application.
>>>> > Thank you.
>>>> > Best Regards.
>>>> > Leônidas
>>>> > Em qua., 22 de abr. de 2020 às 19:58, Stefano Campus <
>>>> > <mailto:skampus at gmail.com>> escreveu:
>>>> > ciao,
>>>> > sorry if I re-propose the theme.
>>>> > is it possible to remove from transifex the set of strings to be
>>>> > translated from the old versions of qgis?
>>>> > We have Resource that are not editable from:
>>>> > thank you in advance for your reply
>>>> > s.
>>>> > _______________________________________________
>>>> > QGIS-Translators mailing list
>>>> > Qgis-tr at lists.osgeo.org <mailto:Qgis-tr at lists.osgeo.org>
>>>> > https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20200423/39fe2c24/attachment.html>
More information about the Qgis-tr
