[Qgis-tr] Reoccuring strings
Karl Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Fri Feb 18 02:08:56 PST 2022
The history is that it is new:
0 translations • 1 source edit
%n vertices were not removed
Created by jefi, 9 hours ago via API
It's ok to do it now but if "plurals" is increasing in use and they are not recognized as translated it would be a bigger problem.
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: Richard Duivenvoorde <rdmailings at duif.net>
Skickat: den 18 februari 2022 09:48
Till: Karl Magnus Jönsson <Karl-Magnus.Jonsson at kristianstad.se>; QGIS Translation Discussions <qgis-tr at lists.osgeo.org>
Ämne: Re: Sv: [Qgis-tr] Reoccuring strings
On 2/18/22 09:01, Karl Magnus Jönsson wrote:
> Here are some examples.
> Untranslated string:
> Function `attribute` requires one or two parameters. %n given.
Ok, I searched this one up in QGIS sources, and that one is changed some days ago as part of this 'plural' thing:
https://github.com/qgis/QGIS/blame/master/src/core/expression/qgsexpressionfunction.cpp#L1704
It's not clear (to me) why you should translate it again if you already translated that one yesterday...
Can you see history of that string?
And note that there can be some inefficiency in this translation process...
You could also try to 'download the strings for translation' and see if Linguist is also saying that they are changed?
Sorry, but I hope that somebody else can chip in here...
Regards,
More information about the Qgis-tr mailing list
