[QGIS-trac] Re: [Quantum GIS] #1198: Open attribute table hangs
when a postGIS layer has pending copy from other layer
Quantum GIS
qgis at qgis.org
Fri Aug 1 12:43:48 EDT 2008
#1198: Open attribute table hangs when a postGIS layer has pending copy from other
layer
Reporter: milovanderlinden | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: Digitising | Version: HEAD
Resolution: | Keywords: postgis crash copy paste
Platform_version: Ubuntu Hardy x86_64 | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by milovanderlinden):
More steps for reproduction:
- If I open the postGIS layer and press the button to open the attribute
table, it is there in a split second.
- If I draw a polygon and open the attribute table, split second and I can
see the edit with a -2 id.
- If I copy even a single geometry from the underlying shapefile, hang.
This must definitely have something to do with copying an object, not with
edit a postGIS layer in general.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1198#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
