[QGIS-trac] Re: [Quantum GIS] #605: Building pyramids causes
segfault
Quantum GIS
qgis at qgis.org
Fri Aug 1 14:21:43 EDT 2008
#605: Building pyramids causes segfault
Reporter: gsherman | Owner: timlinux
Type: defect | Status: assigned
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: Rasters | Version: 0.8
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Comment (by msieczka):
Replying to [comment:8 dickeya]:
> One question:
> In the first example you show a ".aux" file of 125M. Shouldn't this be
the ".rrd" file?
My *.aux file is a direct output of a command like 'gdaladdo --config
USE_RRD YES some.tif 2 4 8 16' and the command does not produce anything
else. If you get a file with different extension then I don't know why.
I'm using GDAL 1.5.2 + SVN r15027 FWIW.
> The rrd should contain the pyramids, and in my local tests, this is the
case.
Do you mean gdaladdo output? Please copy&paste the command syntax,
gdalinfo of input file, the list of output files, gdalinfo of what you
believe is the overviews file and your GDAL version.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/605#comment:9>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
