[QGIS-trac] [Quantum GIS] #1205: No valid projection. Unable to set
map units.
Quantum GIS
qgis at qgis.org
Tue Aug 5 18:11:19 EDT 2008
#1205: No valid projection. Unable to set map units.
Reporter: jcs | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: MapCanvas | Version: HEAD
Keywords: QgsSpatialRefSys | Platform_version:
Platform: RedHat | Must_fix: No
Status_info: 0 |
A vanilla build of 0.11.0 produces numerous prints of "No valid
projection. Unable to set map units."
This is unavoidable and can be seen by following the execution of
QgsSpatialRefSys::loadFromDb().
At the top of this function mIsValidFlag is set to false. This variable
is only set to true '''after''' a call to setMapUnits().
But the first thing setMapUnits() does is check mIsValidFlag which in this
case will always be false and the print will be executed.
Moving the mIsValidFlag = true before setMapUnits() fixes the "No valid
projection. Unable to set map units." prints but this may not be what the
author had in mind.[[BR]]
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1205>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
