[QGIS-trac] Re: [Quantum GIS] #1176: Transverse mercator south
orientated projections not supported
Quantum GIS
qgis at qgis.org
Wed Aug 13 12:08:21 EDT 2008
#1176: Transverse mercator south orientated projections not supported
Reporter: halfhaggis | Owner: nobody
Type: bug | Status: reopened
Priority: minor: annoyance or enhancement | Milestone: Version 1.0.1
Component: Projection Support | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by halfhaggis):
I've been communicating with Gerald Evenden who has a lot to do with the
proj4 library.
Via command-line, I can get the correct projections with this sample input
(filename proj2):
26.67029 -30.69927
where first column is longitude and second column latitude
and this command and output
$ proj +proj=tmerc +ellps=WGS84 +lon_0=27 -m -1 proj2
31587.18 3397679.73
The -m flag doesn't work when defining a custom projection in qgis. Is
there some other way to get the -m behaviour when defining custom
projections?
From the proj man file:
-m mult
The cartesian data may be scaled by the
mult parameter. When processing data in
a forward projection mode the cartesian
output values are multiplied by mult oth‐
erwise the input cartesian values are
divided by mult before inverse projec‐
tion. If the first two characters of
mult are 1/ or 1: then the reciprocal
value of mult is employed.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1176#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
