[QGIS-trac] [Quantum GIS] #1223: can't remove a single polygon if it's ID is not unique
Quantum GIS qgis at qgis.org
Wed Aug 20 09:16:01 EDT 2008
   Reporter:  msieczka                          |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.0
  Component:  Digitising                        |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  All                               |           Must_fix:  Yes
Status_info:  0                                 |
 1. Open the attached Shapefile.
 2. Toggle editing.
 3. Navigate to top-left corner.
 4. You can't remove any of the separate polygons cause all have the same
 id - you can only remove all polygons (i.e. the entire geometry in the
 Shapefile) or none.
 QGIS should let the user modify Shapefile's geometry independent of it's
 data table linkage.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1223>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
