[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not
work
Quantum GIS
qgis at qgis.org
Thu Aug 21 06:05:05 EDT 2008
#1079: on the fly projections do not work
Reporter: pcav | Owner: mhugent
Type: defect | Status: closed
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: Projection Support | Version: HEAD
Resolution: fixed | Keywords: srs.db datum
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 1
Comment (by leolami):
Hi all,
the problem seems solved, I tested using a projection like Gauss Boaga
standard (EPSG code=3003)
+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0 +ellps=intl
+units=m +no_defs
I try to reproject with a UTM wgs84 fuse 32N layer and it works well.
A little correlate problem is that if I load a layer from a Location of
GRASS with this parameters of projection:
+proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0
+ellps=intl +units=m +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
when I look the projection associated to this layer I can see that QGIS
doesn't know this projection and that it associates to the layer the
projection setted as default.
But if I create a custom projection like this and I set it as the default
projection when I load the GRASS layer I see that QGIS associates to the
layer the standard projection:
+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
but I remember that before QGIS readed the projection with parameters like
the same projection withot them and it associated to the layer the
standard Gauss Boaga projection (EPSG code=3003)
Do you think we have to reopen the ticket?
Thank you
Leonardo
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1079#comment:10>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
