[QGIS-trac] Re: [Quantum GIS] #1252: QGIS crashes when I use Identify Tool on MULTILINESTRINGS
Quantum GIS qgis at qgis.org
Fri Aug 29 11:56:38 EDT 2008
        Reporter:  hdus                                       |         Owner:  jef
            Type:  bug                                        |        Status:  reopened
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Vectors                                    |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  RedHat
        Must_fix:  No                                         |   Status_info:  1
Changes (by jef):
  * status_info:  0 => 1
Comment:
 Replying to [comment:6 hdus]:
 > Replying to [comment:5 hdus]:
 > > Replying to [comment:4 jef]:
 > > > fixed in r9209
 > > jef thank you very much for the fast fix!!
 > Ooops I was a little bit premature, but the multilinestring issue
 doesn't seems to be fixed, QGIS is still crashing.
 Ok, the fixed bug didn't seem to be related to either multilinestrings or
 postgis anyway.  I spit your shape into postgis and was able to reproduce
 crashes when opening the identify results and clicking multiple times on
 different polygons.
 So there must be something else, which I'm still unable to reproduce.  The
 only thing I noticed is that the postgis table contains POLYGONs only,
 while the bug title is about MULTILINESTRINGs.
 Which GEOS version are you running?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1252#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
