[QGIS-trac] [Quantum GIS] #1255: georeferencer: refuses to delete some GCPs or deletes wrong ones, crashes at times
Quantum GIS qgis at qgis.org
Fri Aug 29 15:35:46 EDT 2008
at times
   Reporter:  msieczka                                   |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.0.0
  Component:  Plugins                                    |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  Yes
Status_info:  0                                          |
 Trunk r9205, QT 4.4.0, Debian testing amd64.
 1. load a bitmap in georeferencer
 2. add 4 GCPs at corners
 3. pres "Create" ("Linear" transformation)
 4. you realise point coordinates are bogus
 5. try to delete all points - one of them will resist (at least for me);
 QGIS also sometimes deletes another point instead of the one you click
 Sometimes deleting the points or if "Create and load" is done instead QGIS
 crashes:
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 0x7f5771f887a0 (LWP 28789)]
 0x00007f5762626f7e in QgsPointDialog::openImageFile (this=0x29afbd0,
 layerPath=
       {static null = {<No data fields>}, static shared_null = {ref =
 {_q_value = 3101}, alloc = 0, size = 0, data = 0x93339a, clean = 0,
 simpletext = 0, righttoleft = 0, asciiCache = 0, capacity = 0, reserved =
 0, array = {0}}, static shared_empty = {ref = {_q_value = 62}, alloc = 0,
 size = 0, data = 0x7f577174085a, clean = 0, simpletext = 0, righttoleft =
 0, asciiCache = 0, capacity = 0, reserved = 0, array = {0}}, d =
 0x7fff7a0bf310, static codecForCStrings = 0x0})
     at /home/shoofi/src/straight/qgis-
 trunk/src/plugins/georeferencer/qgspointdialog.cpp:101
 101         delete *it;
 (gdb) bt
 #0  0x00007f5762626f7e in QgsPointDialog::openImageFile (this=0x29afbd0,
     layerPath=
 #1  0x00007f576261c253 in QgsGeorefPluginGui::on_pbnSelectRaster_clicked (
     this=0x23cdd40)
 trunk/src/plugins/georeferencer/plugingui.cpp:157
 #2  0x00007f5762631bb5 in QgsGeorefPluginGui::qt_metacall (this=0x23cdd40,
     _c=QMetaObject::InvokeMetaMethod, _id=2, _a=0x7fff7a0bf460)
 trunk/build/src/plugins/georeferencer/moc_plugingui.cxx:73
 #3  0x00007f577146d764 in QMetaObject::activate () from
 /usr/lib/libQtCore.so.4
 #4  0x00007f5770f066e7 in QAbstractButton::clicked ()
    from /usr/lib/libQtGui.so.4
 #5  0x00007f5770c8c53b in ?? () from /usr/lib/libQtGui.so.4
 #6  0x00007f5770c8c642 in QAbstractButton::click () from
 #7  0x00007f5770d9a522 in QDialog::keyPressEvent () from
 #8  0x00007f57709da26c in QWidget::event () from /usr/lib/libQtGui.so.4
 #9  0x00007f5770987e5d in QApplicationPrivate::notify_helper ()
 #10 0x00007f57709909d4 in QApplication::notify () from
 #11 0x00007f5771459411 in QCoreApplication::notifyInternal ()
    from /usr/lib/libQtCore.so.4
 #12 0x00007f5770a15d04 in ?? () from /usr/lib/libQtGui.so.4
 #13 0x00007f5770a17fbe in ?? () from /usr/lib/libQtGui.so.4
 #14 0x00007f57709f1f10 in QApplication::x11ProcessEvent ()
 #15 0x00007f5770a199cc in ?? () from /usr/lib/libQtGui.so.4
 #16 0x00007f576d521892 in g_main_context_dispatch ()
    from /usr/lib/libglib-2.0.so.0
 #17 0x00007f576d52501d in ?? () from /usr/lib/libglib-2.0.so.0
 #18 0x00007f576d5251db in g_main_context_iteration ()
 #19 0x00007f577148183f in QEventDispatcherGlib::processEvents ()
 #20 0x00007f5770a1916f in ?? () from /usr/lib/libQtGui.so.4
 #21 0x00007f5771457d22 in QEventLoop::processEvents ()
 #22 0x00007f5771457ead in QEventLoop::exec () from /usr/lib/libQtCore.so.4
 #23 0x00007f577145a37d in QCoreApplication::exec ()
 #24 0x00000000004b2599 in main (argc=1, argv=0x7fff7a0c1518)
     at /home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:683
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1255>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
