[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not
work
Quantum GIS
qgis at qgis.org
Sat Aug 30 04:41:41 EDT 2008
#1079: on the fly projections do not work
Reporter: pcav | Owner: mhugent
Type: defect | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: srs.db datum
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 1
Comment (by msieczka):
Replying to [comment:16 neteler]:
> I confirm that QGIS does not understand data in a GRASS location with
towgs parameter:
> Warning: QgsCoordinateReferenceSystem::getRecord failed : select * from
tbl_srs where
> parameters='+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000 +y_0=0
+ellps=intl
> +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +units=m +no_defs'
> <snip>
QGIS doesn't recognize this CRS, because epsg_tr.py (a GDAL utility, used
in the QGIS CRS database creation script) will not create an exactly the
same string for any EPSG code. I checked that with all EPSG codes against
my GDAL 1.5.2 instalation. Markus, what EPSG code is this proj4 string
supposed to represent?
> Since GDAL considers this projection '''valid''', it must be a QGIS
problem. I take
> liberty to reopen the ticket.
True, the CRS definition is valid, in general, according to testepsg
(another GDAL utility), yet it is not an exact representation of any EPSG
code according to GDAL, as checked with epsg_tr.py.
Looks like the bottom line of the problem is that QGIS uses an overly
strict CRS matching. QGIS should support any CRS definition that GDAL
considers valid, not only those which are exact equivalents of some EPSG
codes.
QGIS devs - can it? The testepsg from GDAL seems to provide the required
functionality.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1079#comment:19>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
