[QGIS-trac] Re: [Quantum GIS] #1079: on the fly projections do not
work
Quantum GIS
qgis at qgis.org
Sun Aug 31 05:15:30 EDT 2008
#1079: on the fly projections do not work
Reporter: pcav | Owner: mhugent
Type: defect | Status: reopened
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: srs.db datum
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 1
Comment (by neteler):
Replying to [comment:19 msieczka]:
> Replying to [comment:16 neteler]:
> > I confirm that QGIS does not understand data in a GRASS location with
towgs parameter:
> > Warning: QgsCoordinateReferenceSystem::getRecord failed : select *
from tbl_srs where
> > parameters='+proj=tmerc +lat_0=0 +lon_0=9 +k=0.9996 +x_0=1500000
+y_0=0 +ellps=intl
> > +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +units=m
+no_defs'
> > <snip>
> QGIS doesn't recognize this CRS, because epsg_tr.py (a GDAL utility,
used in the QGIS CRS database creation script) will not create an exactly
the same string for any EPSG code. I checked that with all EPSG codes
against my GDAL 1.5.2 instalation. Markus, what EPSG code is this proj4
string supposed to represent?
GRASS 6.4.svn (pat):~ > g.proj -j | tr '\n' ' '
+proj=tmerc +lat_0=0.0000000000 +lon_0=9.0 +k_0=0.9996000000
+x_0=1500000.0000000000 +a=6378388 +rf=297 +no_defs
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68 +to_meter=1
It is EPSG 3003 + towgs84 (since PROJ4's epsg file still omits towgs84
when multiple datums are available as in many European countries).
> > Since GDAL considers this projection '''valid''', it must be a QGIS
problem. I take
> > liberty to reopen the ticket.
> True, the CRS definition is valid, in general, according to testepsg
(another GDAL utility), yet it is not an exact representation of any EPSG
code according to GDAL, as checked with epsg_tr.py.
> Looks like the bottom line of the problem is that QGIS uses an overly
strict CRS matching. QGIS should support any CRS definition that GDAL
considers valid, not only those which are exact equivalents of some EPSG
codes.
Right. Currently it is a showstopper which renders QGIS' on the fly
projection unusable as I cannot afford shifts of >100m just due to the
omission of towgs84.
> QGIS devs - can it? The testepsg from GDAL seems to provide the required
functionality.
to compile that:
cd gdal/apps/
make testepsg
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1079#comment:21>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
