[QGIS-trac] [Quantum GIS] #1453: WMS Layer URL is damaged when
loaded via Python
Quantum GIS
qgis at qgis.org
Fri Dec 12 08:36:30 EST 2008
#1453: WMS Layer URL is damaged when loaded via Python
Reporter: hdus | Owner: mhugent
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: WMS | Version: HEAD
Keywords: WMS Python | Platform_version:
Platform: Linux | Must_fix: Yes
Status_info: 0 |
I load a WMS-Layer with
{{{self.iface.addRasterLayer(url,
displayName,service,layerList,styleList,imageType,srs);}}}
All parameters are defined correct. The Layer is loaded to the legend. The
tooltip of the layerconnection shows the correct URL.
{{{http://srsofaioi12288:8080/geoserver/wms?}}}
After check the visibility checkbox QGIS responses with the following
error message:
Could not draw Grundbuchplan because:
WMS Server responded unexpectedly with HTTP Status Code 404 (Not Found)
Tried URL:
http://srsofaioi12288:80/geoserver/wms?SERVICE=WMS&SERVICE=WMS&VERSION=1.1.1&.......
Here you can see two strange things:
1. Port 8080 is changed to port 80
2. SERVICE=WMS appears twice
Loading this WMS via WMS-Connector works without problems.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1453>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
