[QGIS-trac] Re: [Quantum GIS] #1453: WMS Layer URL is damaged when
loaded via Python
Quantum GIS
qgis at qgis.org
Fri Dec 12 10:24:29 EST 2008
#1453: WMS Layer URL is damaged when loaded via Python
Reporter: hdus | Owner: mhugent
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.0.0
Component: WMS | Version: HEAD
Resolution: | Keywords: WMS Python
Platform_version: | Platform: Linux
Must_fix: Yes | Status_info: 0
Comment (by hdus):
Replying to [comment:1 jef]:
> The first url is used for the GetCapabilities request. The
GetCapabilities response contains an url that is used to the GetMap
requests that actually load the images to display.
I checked the Capabilities output and I see a well defined onlineressource
with port 8080:
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:type="simple"
xlink:href="http://srsofaioi12288:8080/geoserver/wms?SERVICE=WMS&"/>
In addition the OnlineRessource shows SERVICE=WMS after ? thats the reason
for the twice SERVICE=WMS, but one 80 is missing. I've to correct my
former post. With the WMS connector QGIS shows the same faulty behaviour.
> I suspect that the OnlineResource returned by GetCapabilities points to
the second url you see. That would be a problem of the WMS server.
> That would be consistent with the fact that if the layer is initially
off, checking the visibility box triggers the first GetMap request.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1453#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
