[QGIS-trac] Re: [Quantum GIS] #1462: PostGIS layer loaded via
 Python is not saved correct in qgs project file
    Quantum GIS
    qgis at qgis.org
    Mon Dec 15 07:11:04 EST 2008
#1462: PostGIS layer loaded via Python is not saved correct in qgs project file
        Reporter:  hdus                                       |         Owner:  jef
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.0
       Component:  Project Loading / Saving                   |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  All
        Must_fix:  No                                         |   Status_info:  0
Comment (by hdus):
 Replying to [comment:1 jef]:
 > I tried to run your code in the python console.  When try to save I get
 > NotImplementedError: QgsVectorLayer.writeSymbology() is abstract and
 must be overridden
 > I still need to investigate why there's python code fired at all at that
 point, but if I replace
 > vlayer = QgsVectorLayer(uri.uri(), layerName, "postgres")
 > QgsMapLayerRegistry.instance().addMapLayer(vlayer)
 > with
 > iface.addVectorLayer(uri.uri(), layerName, "postgres")
 > everything is fine again.
 Your workaround works fine for me too. But how do I load a namedStyle to
 this layer? With my version I can prepare a vLayer object and I'm able to
 add a symbolisation with {{{vLayer.loadNamedStyle()}}} before I register
 the vLayer. I tried
 self.iface.addVectorLayer(uri.uri(), layerName, "postgres")
 vLayer = self.iface.mapCanvas().currentLayer()
 vLayer.loadNamedStyle(Path to qml-file)
 in this case the symbolisation in mapcanvas is updated, but the legend
 symbolisation is not changed.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1462#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
