[QGIS-trac] Re: [Quantum GIS] #1171: Layers disappear and require
restart after first time selection of anti-aliased rendering
Quantum GIS
qgis at qgis.org
Wed Dec 17 20:53:32 EST 2008
#1171: Layers disappear and require restart after first time selection of anti-
aliased rendering
Reporter: springmeyer | Owner: nobody
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.1
Component: MapCanvas | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Comment (by smizuno):
This is a very subtle issue - the problem originally described occurs once
after start up. However, resizing the map canvas causes the map size and
extent to jump when switching from QPixmap to QImage. The map is drawn at
the previous QImage size, then is drawn correctly on subsequent resize. I
have since found that the Render toggle isn't a factor - it just may show
the effects more readily.
My recollection is that the QImage has a size of 0,0 initially, which is
why the map goes blank. After that the object is at its previous size and
hasn't been resized when QPixmap is the rendering object. The key factors
are first use or that the map canvas has been resized.
It is not Qt version related - the problem exists with either 4.3.x series
or 4.4.x.
For what it's worth (I admit, I am biased) I have been applying the patch
each time I obtain the latest svn copy and have not found any other
problem that could be attributed to the patch. I remove the patch and test
without it when I believe there may be a problem related to it.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1171#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
