[QGIS-trac] Re: [Quantum GIS] #1027: The --extent command line option does not appear to work
Quantum GIS qgis at qgis.org
Wed Jul 9 08:42:46 EDT 2008
        Reporter:  masneyb                           |         Owner:  timlinux
            Type:  defect                            |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.0
       Component:  GUI                               |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Changes (by timlinux):
  * owner:  nobody => timlinux
  * milestone:  => Version 1.0.0
Comment:
 Hi
 The extents of the map render scene and the extents of the application
 window are independently of each other. QGIS should remember the window
 size from your previous session (thats what the geometry is for in the
 config file you referred to). Once the window is show the maprender scene
 is set to the spatial extents defined in your .qgs file at a scale
 appropriate to the current window size. If window sizing is still causing
 you an issue, please file a separate bug for that.
 I am moving this bug to milestone 1.0.0. When the upcoming 0.11.0 release
 is out in a week or so, please confirm if this --extents bug still exists
 and if not close this issue.
 Many thanks
 Tim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1027#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
