[QGIS-trac] [Quantum GIS] #1149: selection of multiple postgis
features to shapefile seg faults
Quantum GIS
qgis at qgis.org
Fri Jul 11 07:30:17 EDT 2008
#1149: selection of multiple postgis features to shapefile seg faults
Reporter: arkygeek | Owner: nobody
Type: defect | Status: new
Priority: critical: causes crash or data corruption | Milestone:
Component: OGR Layer support | Version: HEAD
Keywords: postgis select shapefile | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
when selectin multiple features from a postgis layer and right clicking to
save to shapefile, immediate seg fault.
arkygeek at arkygeek-desktop:~/apps/qgis/bin$ ./qgis
Debug:
Debug: QgsApplication state:
Debug: Prefix :/home/arkygeek/apps/qgis
Debug: Plugin Path :/home/arkygeek/apps/qgis/lib/qgis
Debug: PkgData Path :/home/arkygeek/apps/qgis/share/qgis
Debug: Theme Path :/home/arkygeek/apps/qgis/share/qgis/themes/default/
Debug: User DB Path :/home/arkygeek/apps/qgis/share/qgis/resources/qgis.db
Debug: **********************************
Warning: No valid projection. Unable to set map units.
Debug:
Loaded /home/arkygeek/apps/qgis/lib/qgis/libcopyrightlabelplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libdelimitedtextplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libdelimitedtextprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgeorefplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgpsimporterplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgpxprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgrassplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgrassprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libgridmakerplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libmemoryprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libnortharrowplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libogrprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libpggeoprocessingplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libpostgresprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libquickprintplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libscalebarplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libspitplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libwfsplugin.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libwfsprovider.so
Loaded /home/arkygeek/apps/qgis/lib/qgis/libwmsprovider.so
Debug: current properties:
Debug: name: properties
Debug: key: <GRASS> subkey: <GRASS>
Debug: name: GRASS
Debug: key: <WorkingLocation> value: shuna
Debug: key: <WorkingGisdbase> value:
/home/arkygeek/GRASSDATA
Debug: key: <WorkingMapset> value: shuna
Debug: key: <Gui> subkey: <Gui>
Debug: name: Gui
Debug: key: <SelectionColorBluePart> value: 0
Debug: key: <CanvasColorGreenPart> value: 255
Debug: key: <CanvasColorRedPart> value: 255
Debug: key: <SelectionColorRedPart> value: 255
Debug: key: <SelectionColorGreenPart> value: 255
Debug: key: <CanvasColorBluePart> value: 255
Debug: key: <PositionPrecision> subkey: <PositionPrecision>
Debug: name: PositionPrecision
Debug: key: <DecimalPlaces> value: 2
Debug: key: <Automatic> value: true
Debug: /home/arkygeek/devel/qgis_unstable/src/core/qgsproject.cpp : 558
unable to find title element
Warning: QFSFileEngine::open: No file name specified
--accepting rule at line 79 ("siteno")
--accepting rule at line 61 ("=")
--accepting rule at line 75 ("2221001")
--accepting rule at line 81 (" ")
--accepting rule at line 59 ("OR")
--accepting rule at line 75 ("2020012")
--accepting rule at line 75 ("2221017")
--accepting rule at line 75 ("2323009")
--accepting rule at line 75 ("2021030")
--accepting rule at line 75 ("2121065")
--accepting rule at line 75 ("2120049")
--accepting rule at line 75 ("2321002")
--accepting rule at line 75 ("2021039")
--accepting rule at line 75 ("2321003")
--(end of buffer or a NUL)
--accepting rule at line 75 ("2021013")
--EOF (start condition 0)
Segmentation fault
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1149>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
