[QGIS-trac] [Quantum GIS] #1153: crash in map composer
Quantum GIS
qgis at qgis.org
Sun Jul 13 06:51:10 EDT 2008
Reporter: msieczka | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 0.11.0
Component: Printing | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: Yes
Status_info: 0 |
QGIS crashes in map composer.
1. open the attached project (you will need to modify the path to the
shapefile used; it's attached too)
2. press "Print" button
3. crash:
Debug: /home/shoofi/src/straight/qgis-
trunk/src/providers/ogr/qgsogrprovider.cpp: 335: (getNextFeature) Feature
is null
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsmaprender.cpp:
366: (render) Done rendering map layers
Debug: /home/shoofi/src/straight/qgis-trunk/src/core/qgsvectorlayer.cpp:
295: (drawLabels) Starting draw of labels
422: (render) Rendering done in (seconds): 0.057
scale = 1
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x2b0b450aec80 (LWP 17362)]
0x00002b0b39a0d423 in QPainter::isActive (this=0x10f3af0) at
painting/qpainter.cpp:1426
1426 painting/qpainter.cpp: No such file or directory.
in painting/qpainter.cpp
(gdb) bt
#0 0x00002b0b39a0d423 in QPainter::isActive (this=0x10f3af0) at
#1 0x00002b0b39a0fe89 in QPainter::clipPath (this=0x10f3af0) at
painting/qpainter.cpp:2254
#2 0x00002b0b39aac5fb in QX11PaintEngine::updateState (this=0x11327e0,
state=@0x10e7070) at painting/qpaintengine_x11.cpp:990
#3 0x00002b0b39a12c5a in QPainterPrivate::updateStateImpl (this=0xfc11b0,
newState=0x10e7070) at painting/qpainter.cpp:884
#4 0x00002b0b39a12d3b in QPainterPrivate::updateState (this=0xfc11b0,
newState=0x10e7070) at painting/qpainter.cpp:912
#5 0x00002b0b39a1316c in QPainter::restore (this=<value optimized out>)
at painting/qpainter.cpp:1546
#6 0x00002b0b39e494d8 in QGraphicsScene::drawItems (this=<value optimized
out>, painter=0x7fff719aba30, numItems=4, items=0x10f3a20, options=<value
optimized out>,
widget=0xa080a0) at graphicsview/qgraphicsscene.cpp:4029
#7 0x00002b0b39e684db in QGraphicsView::paintEvent (this=0xa08260,
event=<value optimized out>) at graphicsview/qgraphicsview.cpp:3058
#8 0x00002b0b3996d198 in QWidget::event (this=0x10f3af0,
event=0x7fff719ac130) at kernel/qwidget.cpp:7065
#9 0x00002b0b39e62c5b in QGraphicsView::viewportEvent (this=0xa08260,
event=0x7fff719ac130) at graphicsview/qgraphicsview.cpp:2267
#10 0x00002b0b39469768 in
QCoreApplicationPrivate::sendThroughObjectEventFilters (this=<value
optimized out>, receiver=0xa080a0, event=0x7fff719ac130)
at kernel/qcoreapplication.cpp:694
#11 0x00002b0b3991ae2c in QApplicationPrivate::notify_helper
(this=0x96eda0, receiver=0xa080a0, e=0x7fff719ac130) at
kernel/qapplication.cpp:3768
#12 0x00002b0b39922b2a in QApplication::notify (this=0x7fff719ae8f0,
receiver=0xa080a0, e=0x7fff719ac130) at kernel/qapplication.cpp:3739
#13 0x00002b0b3946a491 in QCoreApplication::notifyInternal
(this=0x7fff719ae8f0, receiver=0xa080a0, event=0x7fff719ac130) at
kernel/qcoreapplication.cpp:587
#14 0x00002b0b3996bbcf in QWidgetPrivate::drawWidget (this=0xa649c0,
pdev=0xa2f2c8, rgn=@0x7fff719ac390, offset=@0x7fff719ac380, flags=4,
sharedPainter=0x10f3af0)
at kernel/qwidget.cpp:4491
#15 0x00002b0b3996c2b5 in QWidgetPrivate::paintSiblingsRecursive
(this=0xabf8d0, pdev=0xa2f2c8, siblings=@0x7fff719ac560, index=0,
rgn=@0x7fff719ac6d0, offset=@0x7fff719ac6c0,
flags=4, sharedPainter=0x10f3af0) at kernel/qwidget.cpp:4589
#16 0x00002b0b3996b888 in QWidgetPrivate::drawWidget (this=0xabf8d0,
pdev=0xa2f2c8, rgn=@0x7fff719ac6d0, offset=@0x7fff719ac6c0, flags=4,
at kernel/qwidget.cpp:4532
#17 0x00002b0b3996c2b5 in QWidgetPrivate::paintSiblingsRecursive
(this=0xa35750, pdev=0xa2f2c8, siblings=@0x7fff719ac8a0, index=0,
rgn=@0x7fff719aca10, offset=@0x7fff719aca00,
#18 0x00002b0b3996b888 in QWidgetPrivate::drawWidget (this=0xa35750,
pdev=0xa2f2c8, rgn=@0x7fff719aca10, offset=@0x7fff719aca00, flags=4,
#19 0x00002b0b3996c2b5 in QWidgetPrivate::paintSiblingsRecursive
(this=0xa32420, pdev=0xa2f2c8, siblings=@0x7fff719acda0, index=0,
rgn=@0x7fff719acaf0, offset=@0x7fff719acf00,
#20 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xa32420, pdev=0xa2f2c8, siblings=@0x7fff719acda0, index=2,
rgn=@0x7fff719acbd0, offset=@0x7fff719acf00,
flags=4, sharedPainter=0x10f3af0) at kernel/qwidget.cpp:4579
#21 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xa32420, pdev=0xa2f2c8, siblings=@0x7fff719acda0, index=3,
rgn=@0x7fff719acf10, offset=@0x7fff719acf00,
#22 0x00002b0b3996b888 in QWidgetPrivate::drawWidget (this=0xa32420,
pdev=0xa2f2c8, rgn=@0x7fff719acf10, offset=@0x7fff719acf00, flags=4,
#23 0x00002b0b3996c2b5 in QWidgetPrivate::paintSiblingsRecursive
(this=0xb15660, pdev=0xa2f2c8, siblings=@0x7fff719ad2a0, index=1,
rgn=@0x7fff719acff0, offset=@0x7fff719ad400,
#24 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xb15660, pdev=0xa2f2c8, siblings=@0x7fff719ad2a0, index=2,
rgn=@0x7fff719ad0d0, offset=@0x7fff719ad400,
#25 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xb15660, pdev=0xa2f2c8, siblings=@0x7fff719ad2a0, index=3,
rgn=@0x7fff719ad410, offset=@0x7fff719ad400,
#26 0x00002b0b3996b888 in QWidgetPrivate::drawWidget (this=0xb15660,
pdev=0xa2f2c8, rgn=@0x7fff719ad410, offset=@0x7fff719ad400, flags=4,
#27 0x00002b0b3996c2b5 in QWidgetPrivate::paintSiblingsRecursive
(this=0xa43b10, pdev=0xa2f2c8, siblings=@0x7fff719ad7a0, index=17,
rgn=@0x7fff719ad4f0, offset=@0xa9c0a8,
#28 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xa43b10, pdev=0xa2f2c8, siblings=@0x7fff719ad7a0, index=18,
rgn=@0x7fff719ad5d0, offset=@0xa9c0a8,
---Type <return> to continue, or q <return> to quit---
#29 0x00002b0b3996c1da in QWidgetPrivate::paintSiblingsRecursive
(this=0xa43b10, pdev=0xa2f2c8, siblings=@0x7fff719ad7a0, index=19,
rgn=@0x7fff719ad990, offset=@0xa9c0a8,
#30 0x00002b0b3996b888 in QWidgetPrivate::drawWidget (this=0xa43b10,
pdev=0xa2f2c8, rgn=@0x7fff719ad990, offset=@0xa9c0a8, flags=4,
#31 0x00002b0b39abf8c9 in QWidgetBackingStore::cleanRegion (this=0xa9c090,
rgn=<value optimized out>, widget=0xa5f500, recursiveCopyToScreen=true)
at painting/qbackingstore.cpp:1035
#32 0x00002b0b39ac0529 in qt_syncBackingStore (rgn=<value optimized out>,
widget=0xa5f500) at painting/qbackingstore.cpp:245
#33 0x00002b0b399781e2 in QETWidget::translatePaintEvent (this=0xa5f500,
event=<value optimized out>) at kernel/qapplication_x11.cpp:4720
#34 0x00002b0b399850e5 in QApplication::x11ProcessEvent
(this=0x7fff719ae8f0, event=0x7fff719ae2e0) at
kernel/qapplication_x11.cpp:3155
#35 0x00002b0b399ac9cc in x11EventSourceDispatch (s=0x97c070, callback=0,
user_data=0x0) at kernel/qguieventdispatcher_glib.cpp:148
#36 0x00002b0b3d95d0f2 in g_main_context_dispatch () from
/usr/lib/libglib-2.0.so.0
#37 0x00002b0b3d960396 in ?? () from /usr/lib/libglib-2.0.so.0
#38 0x00002b0b3d96082f in g_main_context_iteration () from
#39 0x00002b0b394928bf in QEventDispatcherGlib::processEvents
(this=0x978a20, flags=<value optimized out>) at
kernel/qeventdispatcher_glib.cpp:325
#40 0x00002b0b399ac16f in QGuiEventDispatcherGlib::processEvents
(this=0x10f3af0, flags=<value optimized out>) at
kernel/qguieventdispatcher_glib.cpp:204
#41 0x00002b0b39468da2 in QEventLoop::processEvents (this=<value optimized
out>, flags={i = 1905976752}) at kernel/qeventloop.cpp:149
#42 0x00002b0b39468f2d in QEventLoop::exec (this=0x7fff719ae5f0, flags={i
= 1905976832}) at kernel/qeventloop.cpp:200
#43 0x00002b0b3946b3fd in QCoreApplication::exec () at
kernel/qcoreapplication.cpp:845
#44 0x00000000004bc774 in main (argc=1, argv=0x7fff719aeeb8) at
/home/shoofi/src/straight/qgis-trunk/src/app/main.cpp:685
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1153>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
