[QGIS-trac] Re: [Quantum GIS] #384: Add scrollbar for GRASS modules
with many options
Quantum GIS
qgis at qgis.org
Mon Jul 14 11:17:08 EDT 2008
#384: Add scrollbar for GRASS modules with many options
Reporter: massimodisasha at yahoo.it | Owner: timlinux
Type: enhancement | Status: assigned
Priority: major: does not work as expected | Milestone: Version 1.0.0
Component: GRASS | Version: 0.8
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 1
Changes (by timlinux):
* status: new => assigned
* platform: OS X => All
Comment:
Ok I will place each tool in a scroll area when its opened (to address the
vertical oversize issue). For the 'oh my god why are there so many tabs my
window is too wide now' issue, I propose to either do :
* each tool in its own window (quick and easy, may do that to start)
* have an 'active tools' tab which lists just the ones you have opened
and lets you switch between them
With second option above you would have max 4 tabs only:
|| Modules Tree || Modules List || Open Modules || Current Module ||
I will experiment a bit and get back to you on this.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/384#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
